1. AC Question's Avatar
    I got a new gs7 edge and I don't receive push notifications from fb. I have all my notifications turnd on on the fb app and they are all turned on on my phone settings as well. I'm at a loss at this point I have tried everything I know to do here. Can anyone help it have similar problems?
    05-13-2016 09:26 PM
  2. Alonso1230's Avatar
    I have the same problem with email too phone only a week old can't work it out very annoying!
    05-17-2016 07:40 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Does this happen if you turn off all power saving modes? Also, go to Settings>Data Usage, and make sure Restrict Background Data isn't turned on, either universally or specifically for Facebook.
    05-17-2016 04:11 PM
  4. felloffthetruck's Avatar
    First I would get rid of Facebook and a great email app for push is Aquamail.
    05-17-2016 05:38 PM
  5. Bag of Leaves's Avatar
    Like someone else suggested, turn off the battery optimization for any apps you want to get notifications from. Note that there are TWO places to turn battery optimization off! When I first got my phone, I only knew of the one place, but once you found out about the second one in the optimization menu, turning my e-mail apps off in there fixed not getting my push notifications. (I don't have notifications turned on for Facebook.)
    05-17-2016 09:37 PM
  6. fatchevy's Avatar
    Anyone found a solution. I've had my S7 Edge for about 4 months and still no push notifications from Facebook. My gf has the same issue on her s7 edge.
    09-27-2016 02:35 PM
  7. Zeinab Azadbakht's Avatar
    I found the solution you just have to turn on the Sync button from the setting menu. My all other setting are on, but this was off, and I wouldn't get any email notification. I do now
    How come I'm not getting push notifications on my new s7 edge-photo_2017-02-24_08-38-55.jpg
    Hope it helps.
    02-24-2017 08:40 AM
  1. why wont kies update my phone .?
    By queenArmi in forum General Help and How To
    Last Post: 05-14-2016, 12:22 AM
  2. Need help in copying files into my OP2 from PC
    Last Post: 05-13-2016, 09:21 PM
  3. Replies: 0
    Last Post: 05-13-2016, 09:07 PM
  4. how do I perform a full factory reset on a galaxy s3
    Last Post: 05-13-2016, 09:04 PM
  5. Replies: 1
    Last Post: 05-13-2016, 08:58 PM
