1. itsnotmeitsyou's Avatar
    This is a new issue for me on my T-Mobile S7 Edge. Every theme does it. The font and icons stick, but everything else is back to default after a reboot. Anyone else experiencing this?
    05-14-2016 11:12 AM
  2. teeitupmo#WN's Avatar
    Yes, I have had this issue. To me, it's not a big deal. Just re-apply the theme. However, in my case, it does not happen after each reboot. I believe it happens when I have chosen to use a different background than what came with the theme.
    Again, it's not a big deal to me. Most of the time, I don't like the default wallpaper for the theme.
    itsnotmeitsyou likes this.
    05-14-2016 11:53 AM
  3. itsnotmeitsyou's Avatar
    Strange.. I did change the wallpaper, but I always have. It's probably something a factory reset would fix, but I'd rather not. Looks like I'll just stick with the default theme. I use Nova launcher with custom icons and a 3rd party keyboard, so I only choose themes for the notification tray and dialer anyways.
    05-14-2016 01:56 PM
  4. teeitupmo#WN's Avatar
    I thought you were talking about the Samsung themes. For Nova, I just buy icon packs, not themes.
    05-14-2016 02:06 PM
  5. itsnotmeitsyou's Avatar
    I was talking about Samsung themes. I also use Nova with custom icons.
    05-14-2016 02:20 PM
  6. Bag of Leaves's Avatar
    I don't use themes (have yet to find one I like - I hate the icons the most), but the wallpaper that I use (downloaded from Google Play) often disappears (background is all black) after I reset the phone and it won't come back until I set a different wallpaper (my phone shows the one I like as being set and trying to reselect it doesn't work) and then set the one I like again. Weird.
    05-14-2016 09:53 PM
  7. itsnotmeitsyou's Avatar
    Just wanted to follow up. I gave in and did a factory reset, and it did indeed fix the issue. With already receiving a few software updates, I figured it would probably be beneficial to do one anyway.
    teeitupmo#WN likes this.
    05-15-2016 06:13 PM
  8. teeitupmo#WN's Avatar
    It's interested, I did the same. Was sitting at home watching baseball game on TV and said..wth, might as well.
    I haven't noticed whether it helped, I will take your word for it, since you tested.
    I have just setup my base apps and added the baseball theme. Haven't switched paper yet.
    Thanks, good info.
    05-15-2016 06:57 PM
  1. Replies: 3
    Last Post: 11-01-2016, 01:47 PM
  2. nexus 5 won't turning on constantly rebooting at Google
    Last Post: 05-14-2016, 12:41 PM
  3. Why won't daydream continue working all night?
    Last Post: 05-14-2016, 09:39 AM
  4. why is my phone stuck on reboot?
    Last Post: 05-14-2016, 09:03 AM
  5. Replies: 0
    Last Post: 05-14-2016, 04:37 AM
