1. piannetta's Avatar
    Hi there,
    My phone just received a firmware update this evening but I can't seem to find anything on the net to explain what this upgrade brings or fixes to my S7 Edge.
    Does anyone know if there's a website that explains the details behind each firmware version?
    Cheers,
    Pete
    05-15-2016 03:56 AM
  2. Enzo Ardhaoui's Avatar
    Hi Pete,
    Well samsung never explain exactly what are all changes made through an update .
    I am the in same case as you since the S3 .
    Unfortunately there's no where to get the information.
    05-15-2016 04:12 AM
  3. Tim1954's Avatar
    When you get the update, there is an explanation of what you're getting...
    05-15-2016 04:49 AM
  4. chanchan05's Avatar
    Check this site if it helps. It's supposed to be Samsung's site for security updates information
    http://security.samsungmobile.com/smrupdate.html
    05-15-2016 05:19 AM
  5. piannetta's Avatar
    Not really, the notice that pops up is pretty vague. For instance, it says "bug fixes", but I'd like to know which bugs it fixes
    05-15-2016 05:26 AM
  6. piannetta's Avatar
    Thanks for this, it gives a little info but not what I was after. Appreciate the link though
    05-15-2016 05:28 AM
  7. Rukbat's Avatar
    Check the Android site for change notices.
    05-15-2016 11:12 AM
  8. chanchan05's Avatar
    Not really reliable. You know how some manufacturers change stuff. But yeah, I guess there would be several lines in it that would be correct.
    What would be problematic is if it's a manufacturer only update (like Samsung fixing one of their own bugs, etc.)
    05-15-2016 07:36 PM
  1. Anyone on Marshmallow can send screenshots?
    By Winston P in forum Samsung Galaxy Tab S2
    Last Post: 06-03-2016, 09:13 PM
  2. Replies: 8
    Last Post: 05-21-2016, 07:00 PM
  3. Replies: 1
    Last Post: 05-15-2016, 11:20 AM
  4. Replies: 1
    Last Post: 05-15-2016, 11:15 AM
  5. Why can't I get closed captions on netflix
    Last Post: 05-15-2016, 03:37 AM
