1. tshirttan408's Avatar
    So it looks like Android Pay is about to be released in the UK really soon. As I've never used before I was curious to see if NFC has to be left on constantly, or will it start up if it recognises it's being tapped against a payment terminal? Only reason I ask is I don't like the NFC icon being in the status bar all the time!
    05-17-2016 06:25 AM
  2. jaltman's Avatar
    No need to leave it on. It turns on when you use Samsung Pay and turns off when you are done.
    05-17-2016 06:31 AM
  3. tshirttan408's Avatar
    Thanks for the response, Samsung Pay isnt due to be released yet just Android Pay. Do you think it's the same case where you can leave NFC off and it starts up automatically for Android Pay?
    05-17-2016 06:34 AM
  4. TMavC5's Avatar
    If Samsung Pay isn't available for your Bank you won't be able to use it. NFC will work with you use Android Pay or Google Pay. Then you need to enable NFC.
    05-17-2016 11:35 AM
  5. pjwk81's Avatar
    I've NFC turned on always as I use tags and there's no icon in the notification bar.
    05-17-2016 12:13 PM
  1. Replies: 8
    Last Post: 06-23-2016, 04:56 PM
  2. Best NFC tile stickers?
    By Bag of Leaves in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 05-07-2016, 02:02 AM
  3. Replies: 0
    Last Post: 05-03-2016, 06:18 PM
  4. Where are NFC files stored after transfer
    Last Post: 05-01-2016, 02:47 PM
  5. My nfc turns on but it doesn't read anything or tranfer files
    Last Post: 04-30-2016, 12:21 PM
