1. AC Question's Avatar
    i accidentally muted a contact... its on a galaxy s7 edge
    05-17-2016 05:25 PM
  2. j money2's Avatar
    Inside the particular message, select the contact name in the top left hand corner with the down arrow next to. This will open up "conversation settings. Simply tap the notifications bar back to the on position and that takes it off of mute.
    05-22-2016 06:13 PM
  3. superkat265's Avatar
    I have just one contact that is muted only for text messages. I have checked the notifications for them and they are turned on. I have changed them to the default for everyone else. Deleted and added them back in but the same problem.
    Any suggesions?
    I have a galaxy S6
    thanks
    07-17-2016 06:01 PM
  1. Can you download a podcast from Google Play Music to Android Wear Watch?
    By Ralph Basile in forum General Help and How To
    Last Post: 09-16-2016, 10:54 PM
  2. Replies: 3
    Last Post: 05-18-2016, 05:16 PM
  3. How much data does Google Maps use in 4 hours?
    By AC Question in forum Android Apps
    Last Post: 05-18-2016, 12:56 AM
  4. How much data is used when calls are MADE FROM A HOTSPOT consume?
    Last Post: 05-17-2016, 06:50 PM
  5. Replies: 1
    Last Post: 05-17-2016, 04:55 PM
