1. LLcdPH's Avatar
    According to reports, the FM radio in the AT&T S7 Edge is supposed to be activated. Has anybody seen it and of so, where?
    05-18-2016 08:33 AM
  2. NexusGirlX's Avatar
    If they activated it, you need an app to be able to use the FM radio such as Next radio. Don't confuse an FM radio app with a streaming app. You need an FM radio app.
    05-18-2016 09:05 AM
  3. robfil's Avatar
    You also have to have wired headphones plugged in to work as an antenna.
    05-18-2016 10:41 AM
  4. jneusch's Avatar
    It works with Next radio and headphones. I have used it on my AT&T Edge.
    05-18-2016 10:52 AM
  5. NexusGirlX's Avatar
    The app will warn the user when you go to you use if if there are no headphones connected.
    05-18-2016 01:31 PM
  1. NO FM Radio ?
    Last Post: 05-17-2016, 07:33 AM
  2. Replies: 1
    Last Post: 05-16-2016, 06:39 PM
  3. HTC FM Radio App
    By Fathertime in forum HTC 10
    Last Post: 05-15-2016, 11:26 AM
  4. New Radio in May Security update
    By landale in forum Nexus 5X
    Last Post: 05-14-2016, 04:04 PM
  5. cbc radio app repeats words endlessly
    Last Post: 05-11-2016, 02:41 PM
