1. dcmidnight's Avatar
    I never really noticed this before with the S5 because out of habit I would charge it upside down. But now when the Edge is fully charged the screen pops on. Its usually in the middle of the night after I've fallen asleep.
    Like I said, I've never noticed it before because the S5 was upside down. But its hard to get away from on the wireless pad.
    05-18-2016 07:39 AM
  2. NexusGirlX's Avatar
    It happens when plugging in to charge as well. I don't think it can be disabled.
    05-18-2016 08:21 AM
  3. pjwk81's Avatar
    I've noticed that on my car wireless charger too. Has caught me out a few times when it's just lit up in the windscreen. Could never find a setting to turn it off.
    05-18-2016 08:26 AM
  4. Rukbat's Avatar
    You're missing the "phone is fully charged - remove from charger" popup that turns the screen on. With root and Xposed, you can kill that, otherwise just turn the screen off. (Leaving a fully charged phone on a charger just makes sure it's REALLY fully charged [the 100% popup occurs at between 92% and 98%m depending on the phone and the battery].)
    05-18-2016 05:12 PM
  5. Wizzy's Avatar
    You could put a dark sheet of paper on the phone when you charge at night.
    05-19-2016 09:27 AM
  6. TJA3500's Avatar
    Will the S7 charge upside down?
    05-19-2016 02:06 PM
  7. KahneFan's Avatar
    I have my phone set on Do Not Disturb during the night (10 PM - 6 AM), and I don't think this happens while DND is active - I've never noticed it anyway.
    05-19-2016 03:57 PM
  8. meyerweb#CB's Avatar
    Yes, if it's plugged in, or if you set the charging puck upside down on the back of the phone.
    05-19-2016 04:02 PM
  1. Replies: 17
    Last Post: 10-07-2016, 07:53 PM
  2. Replies: 2
    Last Post: 05-18-2016, 05:15 PM
  3. How do view my calendar while on a call?
    Last Post: 05-18-2016, 07:48 AM
  4. I want to install 's health on my Sony smartwatch 3
    Last Post: 05-18-2016, 07:10 AM
