1. jakeypride's Avatar
    So a lot of you have probably seen my thread about leaving a phone on the charger, it did kill it's battery. Now, I'm wondering if I should go use my upgrade to get a new one because of the amazing camera, I'm going to a festival in August so lowlight will be needed, as well as waterproofing. Do you guys think it's worth the upgrade? Or should I just wait for the Note 6?
    05-20-2016 03:39 PM
  2. Truman82's Avatar
    I'd say go for the s7e😊
    05-20-2016 04:34 PM
  3. digitalbreak's Avatar
    I have both
    05-20-2016 04:41 PM
  4. danlnyc's Avatar
    These chargers are designed to kill the power when the phone is at 100%. I still don't believe that your phone has a decreased battery life from overcharging.
    You should just use your upgrade to get the S7E. They say it's one of the best phones ever released.
    05-20-2016 05:15 PM
  5. chanchan05's Avatar
    That's just a safety precaution. But leaving it in too long would cause heat dissipation of the current that's running through the charger into the phone where it is being blocked. The heat has to go somewhere. I'd believe the heat affected the battery since it would constant for at least 3 weeks.
    Anyway, how about just getting a battery replacement? Should be cheaper than getting a new one.
    05-20-2016 05:41 PM
  1. Replies: 49
    Last Post: 03-23-2017, 09:28 PM
  2. When Will AT&T S7 Receive Android N?
    By richv77 in forum Samsung Galaxy S7
    Last Post: 05-23-2016, 03:21 PM
  3. I want to replace Windows 10 with Android
    Last Post: 05-20-2016, 06:31 PM
  4. Replies: 2
    Last Post: 05-20-2016, 06:28 PM
  5. How do i change my keyboard back to the original settings
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 05-20-2016, 05:11 PM
