1. WillStar's Avatar
    My earphones were working fine until about a minute ago...
    Now when I press either the up or down volume buttons, the volume is turned down. I cannot hear out of the right earphone (the one with the control panes) unless I hold the 'select' button, the one that isn't the volume ones.
    PLEASE HELP!
    05-20-2016 08:27 PM
  2. Rukbat's Avatar
    Something tells me that there's a broken wire, so the volume buttons both hit the same function, the right earphone is ungrounded until you hold the select button. It costs more to fix than to replace.
    05-20-2016 09:01 PM
  1. System UI Tuner and menu/icon theme with Marshmallow S5
    By mike bellamy in forum Samsung Galaxy S5
    Last Post: 05-22-2016, 04:18 PM
  2. Google Messenger Notification Issue
    By persim in forum Android Apps
    Last Post: 05-21-2016, 02:06 AM
  3. Touch screen issues after replacing LCD and Digitizer on Core Prime G360V
    By Niteraven13 in forum Samsung Galaxy Core Prime
    Last Post: 05-20-2016, 09:43 PM
  4. Replies: 0
    Last Post: 05-20-2016, 06:39 PM
  5. how do you talk with 2 people at the same time
    Last Post: 05-20-2016, 06:16 PM
