1. love4speechless's Avatar
    On iOS there is an option to turn off the animation for closing in and out of apps. Is there an option to turn them off on this phone?
    05-21-2016 03:12 AM
  2. chanchan05's Avatar
    Settings>Developer Options>Set Animation Scale to off.
    You have to turn of Developer options first though. Seem to have forgotten exactly how, but you're going to go into About phone and repeatedly tap an entry there. I think it was the build number.
    love4speechless likes this.
    05-21-2016 04:02 AM
  3. thegame161's Avatar
    does turning it off help with anything?
    05-21-2016 04:31 AM
  4. fsfty's Avatar
    Settings/about phone/build number. Keep tapping until developer options turn on. Be sure to adjust all 4 animation settings. I set them to. 5x. Makes the phone much faster.
    05-21-2016 06:07 AM
  5. love4speechless's Avatar
    For some reason I pressed the build number and nothing happened o.o
    05-21-2016 09:45 AM
  6. love4speechless's Avatar
    Never mind I figured it out. I was trying to tap model number cause I couldn't find build number
    05-21-2016 09:49 AM
  7. love4speechless's Avatar
    I could only find three not four
    05-21-2016 09:54 AM
  8. chanchan05's Avatar
    On my phone there are also only 3 animation settings that I can find. He probably just made a mistake or something.
    05-21-2016 10:21 AM
  9. fsfty's Avatar
    Yes sorry... Just 3
    05-21-2016 12:37 PM
  10. KBx315x's Avatar
    what does this do?
    05-21-2016 12:58 PM
  11. chanchan05's Avatar
    what does this do?
    It turns off animations.
    KPMcClave likes this.
    05-24-2016 10:12 AM
  12. Lance Redden's Avatar
    I have mine set to 0.5x , feels so snappy now. Love it!
    Posted via the Android Central App on S7 Edge
    05-24-2016 12:16 PM
  13. Xsie's Avatar
    About the developer option. You can make your phone faster? After setting it to go faster, will you always have to be in "developer edition"? Does DE change your phone in operation, features, appearance, etc?
    05-26-2016 01:42 PM
  14. Lance Redden's Avatar
    Idk if it's making the actual phone faster. It's just changing the animation speed so it appears to be faster. Doesn't change or affect the operation of any of the features or the device itself. If your not comfortable with the settings you change, you can always revert back.
    05-27-2016 02:24 AM
  15. ZeneticX's Avatar
    I personally ALWAYS change this to .5x on every phone since I discovered it. This together with Nova launcher's animation set to Fast option, will make every phone fly
    Xsie likes this.
    05-27-2016 05:17 AM
  16. KPMcClave's Avatar
    Developer options is a set of bundled options hidden by default in Android phones (at least all the phones I've had). There are quite a few more than the Animations settings mentioned here, and most you won't need and shouldn't mess around with anyway. That said, if you were to set something that you didn't like or that caused issues, as has been mentioned, you could just set it back.
    The lowering of the default animations speed is a way to make your phone (at least seem) snappier in response. I'd say of the people I see talking about it the past couple of years, most like it and a few prefer to leave the setting as is.
    If you want to activate the Developer options settings:
    1) Go to Settings > About Phone > Build number
    2) Tap on Build Number a number of times (I think it's 7 times)
    As you go you get the little toast messages popping up letting you know you're almost there, and a final one that tells you Developer options are activated.
    3) Go in to your main Settings and scroll down near the bottom to the new Developer options entry.
    4) Find the 3 Animation settings pictured in the screenshot upthread, and change them to either 0.5 or turn off animations completely by setting them to 0.0 (mine are turned off).
    You can then see if you like it and change those Animations back to 1.0 if you don't.
    It's a simple little tweak, but a lot of us dig it.
    Xsie likes this.
    05-27-2016 07:57 AM
  17. Xsie's Avatar
    I'm gonna give it a try. Thanks for your comments!
    05-27-2016 08:50 AM
  18. oks10's Avatar
    I missed the "." from the original post about what to change the animation to and thought it said "5x"... Needless to say, when I set mine to "5x" I thought the poster was crazy until I noticed he actually said ".5x". lol. I have no idea why anyone would ever want to set their animation to 5x or 10x. Why are those even options!? haha
    KPMcClave and Xsie like this.
    05-27-2016 09:11 AM
  1. How do i turn flashlight off on my nexus 5x?
    By AC Question in forum Nexus 5X
    Last Post: 05-21-2016, 11:25 AM
  2. MXQ Android TV Box - Shuts Television Off
    By dforest21x in forum Ask a Question
    Last Post: 05-20-2016, 11:24 PM
  3. how do I or can I turn off hands free mode on the LG3?
    Last Post: 05-20-2016, 09:56 PM
  4. How can I install an app on an off-network device?
    Last Post: 05-20-2016, 06:16 PM
  5. How do i turn flashlight off on my nexus 5x?
    Last Post: 05-20-2016, 04:22 PM
