1. love4speechless's Avatar
    Hi everyone. I doubt there will be one but I was just wondering if there was a keyboard for the edge screen. The screen not recognising me tapping different keys on the edge is annoying but not enough to get rid of this beautiful phone
    05-21-2016 01:54 PM
  2. aldo82's Avatar
    I've used the Samsung keyboard and the Google keyboard (which I prefer) and neither have had problems like that. I can type reliably all the keys so I'm not sure why you are experiencing problems
    05-21-2016 02:06 PM
  3. missmawarlina's Avatar
    Hi, u can adjust and resize the Samsung keyboard to be slightly in the middle so that u don't have to type at the edges as shown in the picture.
    05-21-2016 02:41 PM
  4. love4speechless's Avatar
    https://uploads.tapatalk-cdn.com/2016...21b5e336e3.jpg
    How do you do this? I just changed back to the Samsung keyboard to try it
    Edit: something tells me on this phone I won't be using Swiftkey. It runs over the edges of the phone and makes input of those keys tricky
    05-21-2016 04:36 PM
  5. chanchan05's Avatar
    Not having problems with Swiftkey on my end. It actually stops right before the curves of the edges.
    love4speechless likes this.
    05-21-2016 05:43 PM
  6. love4speechless's Avatar
    https://uploads.tapatalk-cdn.com/2016...df445cd9e1.jpg
    Weird. Some of the keys overlapped on mine though I did use a different theme
    05-21-2016 05:47 PM
  7. love4speechless's Avatar
    See how the letters on each end slightly curve?
    Right now I'm testing the different sizes
    05-21-2016 05:49 PM
  8. missmawarlina's Avatar
    Settings 》Language & Input 》Keyboard & Input Preferences 》Samsung Keyboard 》Keyboard Size
    05-21-2016 06:13 PM
  9. love4speechless's Avatar
    Thank you very much
    05-21-2016 06:17 PM
  10. chanchan05's Avatar
    Do you have the latest update? I just updated last night. I tried the same theme as you and it still the keyboard stops before the edge curves. Altering the size also affects only the keyboard height.
    If it helps, I have version 6.3.4.96 of the app.
    05-21-2016 06:33 PM
  11. love4speechless's Avatar
    https://uploads.tapatalk-cdn.com/2016...87538e7f34.jpg
    No update listed in the store for SwiftKey in my market. So weird. Last update was the 5th of may
    05-21-2016 07:25 PM
  12. love4speechless's Avatar
    We're using different versions. How does that work o.o
    05-21-2016 07:26 PM
  13. chanchan05's Avatar
    And that gets weird. Lol. At least you know the next update fixes your problem.
    How about checking on a web browser?
    05-21-2016 07:33 PM
  14. love4speechless's Avatar
    Is this what you have? It's SwiftKey beta. What do I do uninstall the one and download this one?
    05-21-2016 07:41 PM
  15. love4speechless's Avatar
    Yay finally. Now I'm back to being able to use it properly. Thank you
    05-21-2016 07:44 PM
  16. chanchan05's Avatar
    Actually no I don't have beta. Beta is one version higher than what I am currently using. Im on 96, beta is 97. But hey at least it worked for you.
    05-21-2016 07:50 PM
  17. love4speechless's Avatar
    Lol I wonder why mine was different. Do they have different country zones for some apps on Android. Either way I'm glad I now have a fully functioning keyboard on this beautiful phone. It was the only thing that was bothering me about it. I notice in the update notes they actually mention the S7 Edge. Haha thanks SwiftKey it's HUGELY appreciated
    05-21-2016 07:58 PM
  18. meyerweb#CB's Avatar
    Swiftkey works perfectly for me, even the keys that wrap around to the curved portion of the screen.
    Tatt2014 likes this.
    05-22-2016 12:43 PM
  19. Bag of Leaves's Avatar
    The regular non-Beta version has now been updated with the S7 Edge update (and some other updates).
    love4speechless and Tatt2014 like this.
    05-27-2016 09:51 PM
  20. love4speechless's Avatar
    That was still so weird how there were two ongoing differing versions of the exact same app
    05-27-2016 10:46 PM
  1. how can I access my keyboard
    Last Post: 05-23-2016, 02:08 AM
  2. How to type Spanish Accents on Google soft keyboard?
    Last Post: 05-21-2016, 02:08 PM
  3. Take down keyboArd when finished
    By jimmy white2 in forum Samsung Galaxy S7 edge
    Last Post: 05-21-2016, 01:56 PM
  4. New themes for Google keyboard!
    By TJA3500 in forum Android 7.0 Nougat
    Last Post: 05-20-2016, 10:01 PM
