1. Abby Normal's Avatar
    I just brought home my new Edge.....
    I want to move some ringtones onto it.
    What is the right way to connect my phone to a windows computer ????
    I can connect with a usb cable but that seems to only charge the battery...
    There must be something i need to open or click on........
    Can anyone save me from searching like crazy for the answer ???
    Thanks in advance for any help given
    05-21-2016 03:12 PM
  2. msavic6's Avatar
    Make sure you allow the mtp connection on your phone when you connect it to the computer.
    Once that is done, you just drag and drop files as you wish.
    05-21-2016 03:39 PM
  3. Abby Normal's Avatar
    Thank You...
    Got them all moved over now...
    05-21-2016 03:48 PM
  4. lycan666's Avatar
    Also keep smart switch very handy for backups and side sync is really ultimate, it's mirroring your screen on the pc/laptop and let's you do anything from there call msg etc basically use your phone from your laptop
    05-22-2016 12:39 AM
  1. NIB AT&T Galaxy S7 Edge - Black Onyx
    By rockitdog23 in forum Marketplace Archive
    Last Post: 05-26-2016, 10:31 AM
  2. Not able to import my photos from smartphone to laptop
    Last Post: 05-21-2016, 07:32 PM
  3. Problem with my Samsung Galaxy Tab S SM-T807
    By diegopapito in forum Ask a Question
    Last Post: 05-21-2016, 03:00 PM
  4. Replies: 0
    Last Post: 05-21-2016, 02:41 PM
  5. Hudl 1 hdmi not connecting
    Last Post: 05-21-2016, 02:29 PM
