1. Plucknbach's Avatar
    Is anyone experiencing or hearing a slight rattle on their phone with the camera off? It seems to stop when I turn the camera on I believe it's the ois. Is this normal?
    05-22-2016 06:44 PM
  2. lammy8's Avatar
    Yes I know the answer to this!
    Happened on my S5 too and it's to do with how the camera focuses. Whilst off, it'll rattle but whilst it's being used it will be silent. No problem whatsoever, just don't shake it too much or you could damage it.
    05-24-2016 02:30 AM
  3. Alanhd's Avatar
    Yeah it's the OIS.
    05-24-2016 11:14 AM
  4. Plucknbach's Avatar
    Thanks. I called samsung support and was told to do a factory reset . Will that eliminate the issue. Imo, if its mechanical, it will not. Any opinions?
    05-24-2016 12:27 PM
  5. lammy8's Avatar
    Yeah it's the OIS.
    No it isn't, it's the focusing part of the camera. The S5 rattles and that doesn't have OIS
    05-25-2016 09:55 PM
  6. lammy8's Avatar
    No as it's basically because no power is being applied to the focusing drive on the camera. As soon as power is applied (by opening the camera app) the focusing drive is engaged. Don't worry about it and don't shake it
    05-25-2016 09:56 PM
  1. Replies: 1
    Last Post: 05-24-2016, 04:48 AM
  2. i can't open my settings in my Galaxy slll.
    Last Post: 05-23-2016, 05:30 AM
  3. Replies: 1
    Last Post: 05-23-2016, 02:31 AM
  4. How to add more screens to my LG5 homepage
    Last Post: 05-22-2016, 05:57 PM
  5. why won't my phone give a response?
    Last Post: 05-22-2016, 05:54 PM
