1. shoaib shah's Avatar
    Anyone recieved this update yet:
    Galaxy S7 and Galaxy S7 edge get an update with various bug fixes - SamMobile
    05-23-2016 08:01 AM
  2. aldo82's Avatar
    Not in the UK yet
    05-23-2016 09:11 AM
  3. pjwk81's Avatar
    Is Google now the reason the battery has been so bad since the last update? Not that I'd turn it of, but hopefully this fixes it when it lands (if it's even for my version).
    05-23-2016 10:14 AM
  4. PJRed2008's Avatar
    Is Google now the reason...
    Gsam will tell you which apps are using battery, and how much. If you have to have Google Now (tried it, didn't do anything for me except show junk I had no interest in) that might be an option for you. Regardless, you can't be using that type of app and expect it won' suck the battery down.
    05-23-2016 10:31 AM
  5. NexusGirlX's Avatar
    I never noticed any change in my battery on either one of my two S7 Edge. I updated both of mine. This is the second update this month. Still says May 1 security update.
    05-23-2016 10:43 AM
  6. aldo82's Avatar
    Still on April security in the UK even on an unlocked phone. Not sure why they haven't pushed us any updates for a while when I keep reading about updates coming out elsewhere
    05-23-2016 10:52 AM
  7. pjwk81's Avatar
    GSam tells you very little when you're not rooted. Gave me no more info than the battery settings menu. All my drain shows up as Android System.
    05-23-2016 11:37 AM
  8. PJRed2008's Avatar
    Okay, you must have a different version than I, as mine shows a lot of data with lots of detail. Whatever.
    05-23-2016 11:43 AM
  9. aldo82's Avatar
    I agree. When android system is the main drainer, gsam gives absolutely no useful information at all to try and pin down what it might be
    KPMcClave likes this.
    05-23-2016 11:54 AM
  10. pjwk81's Avatar
    It can't tell you what's keeping your phone awake, which would be the only useful info it could show over the settings menu. Both show Android System with no further useful information on what is actually causing the drain.
    05-23-2016 11:58 AM
  11. shoaib shah's Avatar
    My guess is that with this update they might bundle in the May Security Patch in there seeing that it weighs over 300mb.
    05-23-2016 12:34 PM
  1. iPhone 6s Plus to S7 Edge?
    By uproar in forum Samsung Galaxy S7 edge
    Last Post: 06-05-2016, 11:48 AM
  2. Replies: 1
    Last Post: 06-02-2016, 02:03 AM
  3. T-Mobile S7 Edge Update
    By lyingfromyou in forum Samsung Galaxy S7 edge
    Last Post: 05-23-2016, 10:05 AM
  4. S7 edge wifi question.
    By Runa99 in forum Samsung Galaxy S7 edge
    Last Post: 05-23-2016, 05:51 AM
  5. Samsung Galaxy S7 edge Black screen
    Last Post: 05-23-2016, 05:17 AM
