1. naturalguy's Avatar
    This phone has been great with the exception of one problem. I am losing data connectivity, it happens several times per week. If I toggle airplane mode on/off it fixes it but that is not an ideal situation. Does anyone know how to fix this?
    05-24-2016 06:23 AM
  2. bboysmax's Avatar
    I had a similar issue back when the Samsung A3 came out. It was later fixed with a software update, so unfortunately I can't see there being any fix that you can do yourself until a new update comes along!
    05-24-2016 07:48 AM
  1. Android Marshmallow 6.0.1 Gallery Problem
    Last Post: 02-25-2017, 11:56 AM
  2. How to get past the Google phone lock after a factory data reset?
    Last Post: 05-24-2016, 05:32 AM
  3. Why do I keep losing my network?
    Last Post: 05-24-2016, 04:36 AM
  4. Connection to server lost on youtube.
    Last Post: 05-24-2016, 03:55 AM
  5. Stuck on "checking connection" screen - Micromax Canvas A1
