1. AC Question's Avatar
    I'm using my S7 Edge since friday and I noticed that while browsing or doing other "non heavy" tasks my phone gets warm, especially on the back but also the screen. I then downloaded the app CPU-Z and started to check the temperature in certain situations. When my phone ist resting on a desk, it idles between 24-26 C. When I carry it in my pocket, it idles between 29-32 C. And when I'm using it for more than 2 minutes the heat starts rising to 33-36 C.
    I'm not sure if these numbers are normal for a smartphone but because I can feel the heat so much more than while using my old phone (Z3, which means it had a glass back too) I'm not sure if i got a faulty unit.
    The only explanation I can imagine is that because of the new implemented heat pipe in the S7, the heat which normally would stay in the phone and maybe throttle the processor now gets spreaded onto the back of the phone to cool the processor and thats why I can feel it more than the Z3.
    What temperature do you get and do you have the same experiences of your S7 (Edge) getting warm?
    05-24-2016 11:16 AM
  2. longmtavk's Avatar
    It's normal. U can use CPU-z to check CPU, battery... temperatures...
    05-26-2016 10:49 AM
  1. Samsung Galaxy S7 Edge
    By detfan in forum Marketplace Archive
    Last Post: 05-27-2016, 11:29 PM
  2. Samsung Edge S6 - Connectivity/Sync issues
    Last Post: 05-24-2016, 02:58 PM
  3. S7 Edge Duos, G935F
    By Mdbills484 in forum Samsung Galaxy S7 edge
    Last Post: 05-24-2016, 12:51 PM
  4. Problem setting call waiting on my Samsung S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 05-24-2016, 09:27 AM
  5. Replies: 0
    Last Post: 05-24-2016, 09:03 AM
