1. johnriii's Avatar
    I'm new to the S7E, and I know the AOD fades and brightens, but it just went off...like I couldn't see it at all. Is that normal? Does it have a timer where it comes back eventually? Or is this a glitch with my phone? BTW, I've only seen this one time...so maybe it's an anomaly...
    05-25-2016 09:26 AM
  2. Almeuit's Avatar
    It should stay up I believe. Did you have the phone facing up?
    05-25-2016 09:52 AM
  3. johnriii's Avatar
    Yes, on my desk at work.
    05-25-2016 10:05 AM
  4. torbach1's Avatar
    I've had that happen randomly, but inconsistently since the latest T-Mobile update from a few days ago. Are you on T-Mobile?
    05-25-2016 10:24 AM
  5. johnriii's Avatar
    Nope,I'm on Verizon.
    05-25-2016 10:30 AM
  6. love4speechless's Avatar
    This happened to me on my first day with my phone last week. It just wouldn't turn on even though I had it turned on in settings. I eventually had to factory reset to get it back
    05-25-2016 10:42 AM
  7. pinkvikchick's Avatar
    Mine has done this every once in a while. But 99% of the time, it's there.
    johnriii likes this.
    05-25-2016 11:36 AM
  8. bsteppuhn's Avatar
    Mine does this since the last AOD update. It's random
    05-25-2016 01:53 PM
  9. marzfreerider's Avatar
    Like others, this happens with mine as well. Only since the last AOD update. Push the lock/unlock button and works again.
    Posted with my S7 edge via the Android Central App
    05-25-2016 02:33 PM
  10. johnriii's Avatar
    I'm starting to think it was a random occurrence. I've had the phone 3 weeks now, and this is the first thing that got my attention in a negative way. It's easily the best smartphone I've had out of 6 so far. Luckily, they've all gotten progressively better.
    05-25-2016 07:00 PM
  11. love4speechless's Avatar
    I discovered that that AOD doesn't work when power saving mode is switched on - new phone for me lol
    05-26-2016 10:33 PM
  1. Replies: 3
    Last Post: 05-24-2016, 04:10 PM
  2. Just want to make sure they are gone
    Last Post: 05-24-2016, 06:45 AM
  3. Replies: 1
    Last Post: 05-24-2016, 04:43 AM
  4. Auto enable/disable AOD using Tasker?
    By 4everForever in forum LG G5
    Last Post: 05-23-2016, 01:58 AM
