1. AC Question's Avatar
    Just got an S7 edge. I keep getting a little message at the bottom saying "1 Message Pending Delivery". I check my voicemail and it says there are unsent messages. I tried to resend them, nothing. I tried to delete them, but one of them is about "Visual Voicemail Avatar", which I don't care about at all, but it says because it's about Visual Voicemail Avatar that it cannot be deleted.
    Feel like I have tried everything and am at wit's end.
    05-25-2016 09:37 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you don't use Visual Voicemail, are you able to Disable it in the App Manager?
    05-25-2016 10:51 PM
  3. Bro Dameron's Avatar
    Thanks for the response.
    No, Visual Voicemail is not in my list of apps in the app manager. The regular voicemail is, though I couldn't find any options that helped there. Thoughts?
    05-26-2016 07:33 AM
  4. B. Diddy's Avatar
    Sorry, but I'm not sure how your phone's messaging works. It's odd that there would be "unsent" voicemail messages--I usually associate unsent messages with the SMS/MMS app.
    05-26-2016 11:47 AM
  1. Messaging app no showing messages
    Last Post: 05-25-2016, 12:28 PM
  2. Why am I unable to play music on my Jabra Freeway from my Galaxy S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 05-25-2016, 10:47 AM
  3. Restrict app deletion by dragging it to trashcan.
    Last Post: 05-25-2016, 10:46 AM
  4. Verizon and video calling
    By Leslie Hatcher in forum Samsung Galaxy S7 edge
    Last Post: 05-25-2016, 09:06 AM
  5. How do I set my signature for text messages on my S7?
    Last Post: 05-25-2016, 08:01 AM
