Save big + get 3 months free! Sign up for ExpressVPN today
  1. Wizzy's Avatar
    Anybody else get the new edge panel update that allows you to insert and arrange any widget on an edge panel. This makes using the edge panels much more useful in my opinion.
    Posted via the Android Central App from my S7 edge
    05-25-2016 07:38 PM
  2. chanchan05's Avatar
    I thought that was just something you bought off the Galaxy Store. I saw that a few weeks back for sale among the other Edge panels available for download.
    05-25-2016 07:43 PM
  3. Wizzy's Avatar
    Interesting. I got it today as an automatic free update to my edge panels.
    Now that I look at it closer, it seems that not all widgets are eligible. They probably have size limitations.
    05-25-2016 07:47 PM
  4. chanchan05's Avatar
    Checked at the updates in Galaxy App Store. Yep the author isn't listed as Samsung but someone named Sally. No idea why they pushed it automatically.
    05-25-2016 08:11 PM
  5. Wizzy's Avatar
    Okay, I must have installed this before. I thought it was from Samsung. D'oh! Please ignore!
    05-25-2016 08:25 PM
  6. Bag of Leaves's Avatar
    Yeah, it is from the Galaxy app store, but to answer your question, yes, I use it. It is probably my least-used panel, since I don't really have widgets that I would prefer to have in the panel instead of on a home page. So, on the panel, I just have a dumb date/time widget that I made in Zooper (just trying it out and I will eventually change it), a slideshow, the icon for the thing where Google tells you what song you're hearing (basically only because I didn't want to leave the space blank), the voicemail icon, and the Google Voice widget. (I recently changed this and used to have it the slideshow, wake-up alarm, voicemail icon, Google Drive icon, and Beep'nGo widget.)
    05-26-2016 03:29 PM
  7. pjwk81's Avatar
    I tried it out before and had it disabled as it just didn't look right. A lot of the third party ones don't.
    The update just reminded me to uninstall it completely.
    05-26-2016 03:46 PM
  8. terung_sekamat's Avatar
    What name this panel??
    09-08-2016 06:01 AM
  9. chanchan05's Avatar
    Widget panel
    09-08-2016 06:27 AM
  1. Replies: 2
    Last Post: 05-26-2016, 10:51 AM
  2. Replies: 1
    Last Post: 05-25-2016, 10:35 PM
  3. Replies: 0
    Last Post: 05-25-2016, 06:27 PM
  4. Galaxy S7 Edge stopped vibrating after resent update
    Last Post: 05-25-2016, 04:42 PM
  5. Replies: 0
    Last Post: 05-25-2016, 02:27 PM
