1. pdizzle27's Avatar
    For the last few days I've had shadows of horizontal lines, come and go. I haven't figured out a pattern of when it occurs, but I'm pretty sure they're not supposed to be there. Any advice?
    05-26-2016 12:46 PM
  2. H3aTeRzz's Avatar
    Hi there!
    I don't see them in the pic you provided. I would suggest running your phone in safe mode, for a long enough period, that the problem would normally occur. If it doesn't occur, then perhaps its an app that's causing it, in the background. If it still occurs, I would bring it to a service center.
    Chris
    05-26-2016 05:38 PM
  3. pdizzle27's Avatar
    Thanks. It never occurred to me to look at the screen shot on another device. Kind of funny that I was looking at the same lines. On to safe mode.
    05-26-2016 09:36 PM
  4. savnout's Avatar
    I think your talking about the lines that appear on the sides when you get a phone call or an alarm when the phone is set face down on its screen ...cool feature....like glowing lines down the sides of the edge bars.
    05-27-2016 08:39 AM
  1. Weird lock screen colour glitch
    Last Post: 05-26-2016, 12:45 AM
  2. What is this weird notification icon?
    By lotus11 in forum Ask a Question
    Last Post: 05-25-2016, 10:46 PM
  3. phone non responsive screen turned grey with blue lines
    Last Post: 05-25-2016, 10:20 PM
  4. Weird performance issues since this week's T-Mobile security update
    By torbach1 in forum Samsung Galaxy S7 edge
    Last Post: 05-25-2016, 10:37 AM
  5. I have a weird symbol on my status bar like a do not enter
    Last Post: 05-25-2016, 05:12 AM
