1. mlblack16's Avatar
    When I use Scout, I have to go into the application manager to force stop Scout when I'm done. Otherwise, it continues to keep GPS active and kills my battery. The location icon in the taskbar stays on and the only way to get it to stop is forcing the app to stop.
    Is anyone else experiencing this? I'm on Verizon.
    05-26-2016 05:49 PM
  2. Rukbat's Avatar
    GPS uses so little data that you can run it until the battery dies and you probably won't notice the difference. It only starts drawing current when an app asks it for the location. (If Scout is doing that continuously after you end it normally, 1) it's a poorly written app and 2) you should be able to long-press the Home button, then wipe it off.)
    05-26-2016 06:01 PM
  3. mlblack16's Avatar
    I'm not sure if it's calling on location, but I know Scout is the only GPS app that my location icon stays on so it's not worth the risk to me. It seems to be an issue with the app not closing properly on the S7.
    05-26-2016 07:26 PM
  4. Bag of Leaves's Avatar
    I have used it on this phone (Sprint version) and had no problems with the GPS staying on after closing it. (I normally just use the GPS built into my car, so don't use Scout often.)
    05-27-2016 12:39 AM
  1. Are there any WhatsApp 3rd party apps I can use?
    By Loc22 in forum WhatsApp for Android
    Last Post: 05-26-2016, 11:15 PM
  2. Replies: 0
    Last Post: 05-26-2016, 05:28 PM
  3. Can the galaxy s6 use a 5g wifi connection?
    Last Post: 05-26-2016, 03:40 PM
  4. Wireless charging when using Android Auto
    By jalan94 in forum Android Auto
    Last Post: 05-26-2016, 03:19 PM
  5. Are there any WhatsApp 3rd party apps I can use?
    By Loc22 in forum Ask a Question
    Last Post: 05-26-2016, 11:04 AM
