1. PsychDoc's Avatar
    This is with my wife's Note 2 but that's a pretty dead forum at this point so I thought I'd ask here as pretty much everything is the same in terms of the issue I'm having trouble with. I hope this is alright.
    I've selected swiftkey as the default keyboard but the phone keeps going back to the stock samsung keyboard on its own. I've even tried to disable the Samsung keyboard in the App Manager and this doesn't work either.
    Any ideas on how I can get swiftkey to stick?
    05-27-2016 09:25 AM
  2. N4Newbie's Avatar
    05-27-2016 09:51 AM
  3. Javier P's Avatar
    Check your battery optimisation settings and make sure Swiftkey is disabled there.
    http://forums.androidcentral.com/sam...k-samsung.html
    05-27-2016 11:18 AM
  4. PsychDoc's Avatar
    Can you provide me with a step-by-step guide to getting into the "battery optimization" settings? I have no idea how to do this. If it helps, the phone is a Verizon Note 2.
    TIA
    05-27-2016 11:35 AM
  5. N4Newbie's Avatar
    If your phone is on Marshmallow, Settings -> Battery -> [menu at top right] -> Battery Optimization. Not Marshmallow? Then does not apply.
    But, I don't think that would have anything to do with it.
    Perhaps...
    05-27-2016 12:19 PM
  6. Javier P's Avatar
    I've never used that particular phone so not sure what the right steps are. Try in settings - battery and search for an overflow menu (three dots, menu key). This seemed to work in other Samsung devices, for example here.
    http://forums.androidcentral.com/sam...d-default.html
    Also, it seems that SideSync needs the stock keyboard to work. Are you using it? If not maybe try disabling it.
    http://forums.androidcentral.com/sam...-keyboard.html
    05-27-2016 12:25 PM
  1. Need to clean the junk!
    By Pastorhss in forum Samsung Galaxy S7 edge
    Last Post: 05-28-2016, 07:36 AM
  2. How strong is the GS 7 edge casing, glass?
    Last Post: 05-27-2016, 07:40 PM
  3. Phone won't stay on SwiftKey
    By PsychDoc in forum Verizon Galaxy Note 2
    Last Post: 05-27-2016, 12:55 PM
  4. Replies: 1
    Last Post: 05-27-2016, 09:00 AM
  5. The new Axon 7
    By Golfdriver97 in forum Axon 7 & Axon 7 mini
    Last Post: 05-27-2016, 08:53 AM
