1. MichaelDeHavilland's Avatar
    I use three phones for business, personal and overseas sim cards.
    Up to now they have all been iPhones (1 x 6 Plus & 2 x 5s')
    I have purchased the S7 Edge for Business and have the iPhone 6 Plus for personal use.
    I have unsuccessfully attempted to move my collection of SMS texts, going back to 2010 to the S7 Edge.
    Samsung Smart Switch moved my calendar and contacts over without any problem, but there is no option to move SMS over.
    Isms2droid just got stuck all the time and I read it doesn't work with IOS 9!
    Android Converter doesn't work either.
    I still have my SMS history on the two remaining iPhones that I use, but I would prefer to have it on the S7 as I don't always have immediate access to my iPhones when out and about.
    Is there a way of transferring messages from an iPhone using iOS 9 to a Samsung Galaxy S7 Edge that works?
    Surely every former Apple user hasn't abandoned their SMS history or been forced to keep a spare iPhone around!
    05-28-2016 12:22 PM
  2. mitul_mehta's Avatar
    Check Google store for transfer of content from iPhone to Android. I think there is one which should help.
    05-28-2016 12:41 PM
  3. gavo360's Avatar
    05-28-2016 03:32 PM
  4. NickA's Avatar
    I use Smart Switch. Backup your iPhone via iTunes first. Start Smart Switch and pick the latest backup. Select messages and it will copy them to your Edge.
    05-29-2016 01:15 AM
  5. MichaelDeHavilland's Avatar
    Thanks for the replies, Smart Switch will not transfer my texts. I believe having, read elsewhere, Smart Switch doesn't work with text transfers with IOS 9.
    I will follow gavo360's link and report back.
    05-29-2016 08:55 AM
  6. cdd543's Avatar
    Smartswitch worked great for me using the adapter that came in the box. Didn't use iCloud backup. Transfers texts with no issue from 6s plus to 7edge.
    05-29-2016 05:41 PM
  7. MichaelDeHavilland's Avatar
    Thanks for that cdd543, I have the iPhone 6 plus.
    I will give it another try with Smartswitch and the adapter.
    06-02-2016 10:56 AM
  8. MichaelDeHavilland's Avatar
    Hooray!!!!
    Thanks cdd543 and NickA,
    I finally managed to transfer all my sms messages dating back to January 2010!!
    1: Download Smartswitch to computer.
    2: Connect iPhone 6 plus to Mac and using iTunes, backup iPhone 6 plus, ensuring the backup is not encrypted.
    3: Disconnect iPhone 6 plus from computer. (no longer needed)
    4: Connect Samsung Galaxy S7 Edge to Mac using original Samsung cable (won't work with a third party cable!).
    5: Open Smartswitch on Mac.
    6: Message with appear on Samsung Galaxy S7 Edge - Answer yes.
    7: Select the latest iPhone backup on the Mac.
    8: Depending how much data is backed up the message 'List of backup files is being loaded'will appear.
    8a: Be prepared for a very long wait (I think mine was around 20 minutes, might have been longer). I had used about 60GB on my 128GB.
    9: Eventually everything will download and you will be presented with about 10 boxes to choose from.
    10: Tick the boxes you wish to restore to the Samsung phone.
    11: Transfer is very quick. (in my case a minute or so for messages, phone log, alarms and one other).
    Note:
    I had been using the Samsung for a number of weeks and built up quite a collection of new texts, so was relieved to see the restored texts were added to these and didn't overwrite them.
    Joy of joys.......
    06-02-2016 01:30 PM
  1. Samsung Galaxy S5 Neo - adjust custom ringtone frequency?
    Last Post: 06-15-2016, 10:36 AM
  2. USB OTG file transfer goes from 25 MBPS to bps
    Last Post: 05-31-2016, 08:07 AM
  3. Droid Turbo 2, can't turn WIFI notifications off
    By klasdude in forum Motorola Droid Turbo 2
    Last Post: 05-30-2016, 04:42 PM
  4. Pathetic S7 Vibration
    Last Post: 05-30-2016, 12:48 PM
  5. Samsung galaxy s3 failed to to register network
    Last Post: 05-28-2016, 04:44 PM
