06-03-2016 05:54 PM
74 123
tools
  1. love4speechless's Avatar
    Mines normally in the 20s
    23 currently
    It is so weird. Last week it was as low as you said but since the update it has increased
    05-31-2016 10:47 PM
  2. refaelagronov's Avatar
    I understand it is boring to put your phone in Ultra Power Saving mode, but it might help us rule out if your battery is bad or if some process is causing the issue.
    Yea i know , i bought this phone to play all.day , actualy the phone is beast , this issue started 3 days ago maybe because im charging it 2 much?
    06-01-2016 01:31 AM
  3. ClintRo's Avatar
    I dont think the issue is charging it too much. Based on your previous screen shot you would hit 10 hours with a little over 4 hour screen on time. Are you playing games or just general web surfing? Are you in a strong cell signal area? how does this compare to other phones you have used in the same areas and manner?
    06-01-2016 07:13 AM
  4. ClintRo's Avatar
    So anyone that has battery life issues should try this. Mine wasnt bad, but I wasn't getting as good of battery life as others. Tried this Package Disable Pro for $0.99 USD and wow.... It has only been less than a day but I am see a noticeable difference. I haven't noticed anything that I am missing in the functionality of the phone so far.
    http://forums.androidcentral.com/sam...n-s7-edge.html
    KPMcClave likes this.
    06-01-2016 07:27 AM
  5. pjwk81's Avatar
    Mine doesn't even compare with this same phone a couple of months ago and from what I gather a lot of users are reporting the same since a software update.
    06-01-2016 07:30 AM
  6. Iva_LadyDiCaprio98's Avatar
    I am using this and I notice no difference. My battery life is still draining
    06-01-2016 07:34 AM
  7. ClintRo's Avatar
    Did you disable all the same packages as the OP in that thread?
    06-01-2016 07:38 AM
  8. Badboy8813's Avatar
    uninstall google fit if you have it installed
    06-01-2016 10:27 AM
  9. Thomas Gruver's Avatar
    I've lost 22% in 80 minutes from full charge.... started a few days ago. No new apps.
    Samsung mail app seems to be running highest.
    06-01-2016 11:25 AM
  10. cowboys2000's Avatar
    I have an S6, I use Gmail, Yahoo Mail and Outlook Web Access as my email clients.
    I set them to only check email every 30 or 60 minutes.
    I had U-verse and the email uses Yahoo Servers. I found that using the actual Yahoo app, changes made in the app (like deleting emails and folders, translate to the yahoo mail website as well. But, using the Google mail app, emails stayed on the "server" unless you go in an tweak the settings.
    06-01-2016 12:24 PM
  11. marlin29311's Avatar
    Best bet is to either disable the app, or clear the app data and then wipe your cache partition...looks like something got buggy.
    06-01-2016 12:25 PM
  12. love4speechless's Avatar
    Can someone tell me how to lower the Android OS. It's constantly close to 40%
    06-01-2016 01:13 PM
  13. danwwright's Avatar
    Perhaps a stupid question on the use of the app, but does it save the disabled app settings after a restart, or do you have to do the Export and re-import?
    06-01-2016 02:44 PM
  14. andrew_ackley's Avatar
    Guys, if you get a chance to buy the exynos version in the US instead of the snapdragon do it. The lack of Samsung Pay kinda sucks but man, the battery life is leaps and bounds better on the exynos. I use cricket bc I get unlimited data on AT&T towers for $65 a month. That could have something to do with it but I was using 2 different AT&T branded S7 Edge. Maybe all of that bloatware does more than just take up space. I always disable them as soon as I setup a device. Any ideas why the battery is so much better for me on the Exynos?
    Maybe it is just Samsung getting more time with the exynos so it is optimized better. There are a couple of reviewers on Youtube that have had similar findings.
    06-02-2016 07:41 AM
  15. tstolz's Avatar
    The guys on this thread seem to have been able to get Samsung Pay working. But flashing a new firmware and all is a bit foreign to me... Anyone here have experience doing that? Any success with Samsung Pay on an Exynos version with 2 sims?
    06-02-2016 07:48 AM
  16. love4speechless's Avatar
    It's one of the few times its been a good thing to be from Australia in regards to technology lol. Yesterday my Exynos version lasted eight hours and 25 minutes screen on time
    06-02-2016 09:48 AM
  17. ClintRo's Avatar
    Yea... the SD 820 on Verizon will never get those kind up numbers unless I go Airplane Mode all day...LOL
    06-02-2016 10:08 AM
  18. Jonnny4's Avatar
    I have the AT&T s7 edge and with no power savings on the lowest I have seen mine is at 69% after a 14 hour day. The Verizon must be running some serious background apps.
    06-02-2016 10:29 AM
  19. tinybfk's Avatar
    What's your SOT?
    Posted via Carrier Pigeon.
    06-02-2016 10:47 AM
  20. ClintRo's Avatar
    From my understanding it is the network that uses more power... but I get great signal EVERYWHERE so I put up with it.
    When I changed from GSM network to CMDA i noticed a drop in battery on the same model of phone.
    06-02-2016 11:54 AM
  21. tnt4's Avatar
    Battery hand-holding. Still a PITA on Android. I love you Android but I'm tired of this type of stuff and seeing these threads on almost every flagship that comes out. It shouldn't be this complicated after all of these years IMHO.
    06-02-2016 04:02 PM
  22. GMC262's Avatar
    I don't think it's just Android though; when working events, I encounter a lot of iPhone users looking wall outlets
    06-02-2016 05:44 PM
  23. Altema22's Avatar
    It's not complicated unless some makes it so, or gets the occasional bad application or bad device. I do battery testing of both Android and iOS devices, so don't even pretend it does not happen to iPhones. It is a more controlled environment, but it still happens on occasion. My wife pulled her HTC out of the box and has been using it for over a year. Her phone has never run out of power in less than a day, and she usually end up with more than 50% at bedtime. She's a big music and YouTube user as well, in addition to having wifi, Bluetooth, 4G LTE data, and GPS on 24/7. This is her first non-Apple phone, and she's lovin it. The other aspect is that Apple intentionally skews the battery percent display to give the users a perception of better battery life. This is why Apple does not allow any apps that display the actual battery voltage.
    06-03-2016 05:46 PM
  24. pjwk81's Avatar
    Not always the case. I had outstanding battery, got a system update, didn't change one app or setting, and now have very average battery that's coming in around 50% of the screen time that I had before.
    06-03-2016 05:54 PM
74 123
  1. S7 Black paint flaking under glass
    By JayWales in forum Samsung Galaxy S7
    Last Post: 09-06-2016, 01:20 AM
  2. Replies: 3
    Last Post: 06-10-2016, 03:42 PM
  3. Why my s7 still lock using trusted location?
    Last Post: 06-08-2016, 04:12 AM
  4. why does my s4 turn itself off when battery still 50% full
    Last Post: 06-08-2016, 02:57 AM
  5. Where can I get a replacement Battery for my sec gen Moto X?
    Last Post: 06-08-2016, 02:55 AM
