1. ogio's Avatar
    went to the park today. sat down for a bit to browse the phone. after a little bit, the screen seemed to go to around half brightness. the brightness was set to auto and showed being maxed. i tried moving the brightness slider, and it would jump back to full. it was acting weird. i couldnt move the brightness slider. does the brightness get over-riden if the phone gets too hot? it was 80 degrees today.
    worked ok afterward, but not earlier in the sun.
    05-29-2016 10:33 PM
  2. anon(9691750)'s Avatar
    I tend to think its the screen sensors doing their job. Whats your daily driver?
    05-29-2016 11:56 PM
  3. bullittmustang's Avatar
    Mine does the same thing sometimes. When it does, the white parts on the screen don't even look white anymore, they have a grayish look to them.
    05-30-2016 06:58 AM
  4. ogio's Avatar
    bmw x5
    but seriously, i have the s7 edge. with the old note, the screen would go into a white mode in the sun. not sure how this s7 edge is supposed to act in the sun.
    05-30-2016 09:41 PM
  5. ogio's Avatar
    exactly like mine.
    05-30-2016 09:41 PM
  6. anon(9691750)'s Avatar
    bmw x5
    It is normal. I have the s7 also. The brightness slider bar is supposed to increase under the sun to make sure the screen is visible to the user. That said, the screen IS supposed to get brighter under the sun. So what is happening for you is totally normal.
    05-30-2016 10:21 PM
  7. anon(9691750)'s Avatar
    bmw x5
    Also the phone is gonna naturally get hot because its metal and glass under sun.
    05-30-2016 10:22 PM
  1. video stabilization in Dev 3?
    By Bpschoon81 in forum Nexus 6P
    Last Post: 05-31-2016, 01:49 PM
  2. Replies: 1
    Last Post: 05-30-2016, 12:27 PM
  3. Replies: 0
    Last Post: 05-29-2016, 09:42 PM
  4. i can't access the Play Store or Play Books
    Last Post: 05-29-2016, 09:18 PM
  5. Replies: 0
    Last Post: 05-29-2016, 09:08 PM
