1. KBx315x's Avatar
    Does anyone know another app that works with the always on display to show other notifications other than just texts? The LG G5 shows more than just texts example Facebook email BBM etc
    05-30-2016 03:47 AM
  2. KBx315x's Avatar
    I don't see any settings for that
    05-30-2016 04:52 AM
  3. chanchan05's Avatar
    Nope. The AOD on the Samsung works only for the default sms and email apps. It's one of the cons in picking it over the G5.
    05-30-2016 05:02 AM
  4. RichBrown68's Avatar
    Pretty much the only con of picking it over the LG G5. And even at that the always on display on the Samsung phones is much brighter than on the LG.
    05-30-2016 07:31 AM
  5. sangs's Avatar
    The AOD on the S7 and S7 Edge is pretty useless, unless you need to check the time compulsively.
    05-30-2016 08:04 AM
  6. KBx315x's Avatar
    Thanks guys
    05-30-2016 08:21 AM
  1. Replies: 2
    Last Post: 05-31-2016, 05:11 AM
  2. Replies: 1
    Last Post: 05-30-2016, 11:36 AM
  3. Stock email can't display any pdf files
    By kaienish in forum Samsung Galaxy S7 edge
    Last Post: 05-30-2016, 06:43 AM
  4. Replies: 0
    Last Post: 05-30-2016, 02:10 AM
  5. Touch quits working after Digitizer Replacement on S4
    Last Post: 05-30-2016, 12:25 AM
