1. ekendraed's Avatar
    On my S7 Edge, the screen goes blank when I make a call. It remain blank even after the call has ended.
    To restore the screen I have to press the " home" button.
    How can I prevent the screen from going blank during a call. I would not mind the screen going blank if I take the phone to my ear
    05-30-2016 08:14 AM
  2. chanchan05's Avatar
    Do you have a screen protector? You likely have something covering up or affecting the proximity sensor. The phone is not supposed to go black during a call.
    05-30-2016 09:19 AM
  3. ekendraed's Avatar
    Yes I have a screen protector/ The proximity sensor is still visible through the protector.
    Is there a remedy??
    05-30-2016 09:37 AM
  4. joe_fresh's Avatar
    get a screen protector that does not cover the sensor. My sensor and cam ar not covered at all.
    05-30-2016 11:16 AM
  5. ekendraed's Avatar
    My sensor is NOT covered
    05-30-2016 06:34 PM
  6. chanchan05's Avatar
    Get an app called Sensors Test from the Play Store. Then use it to test the proximity sensor if it's working properly. That sensor is responsible for turning the screen black during calls when placing it near your head.
    Just a question, if the screen is black during a call, if you press the home button, does it light up?
    05-30-2016 06:54 PM
  7. ekendraed's Avatar
    Yes downloaded the app and ran it.
    Not sure what it is supposed to do though.
    Also downloaded the Proximity Sensor Test and ran it too.
    Still the screen goes blank on a call but lights up when I press the home button
    Would be nice to see the screen at least when I make a call from the palm of my hand without having to press the home button
    05-30-2016 07:09 PM
  8. chanchan05's Avatar
    Ah I see. Your proximity sensor is working fine. You're just seeing standard screen time out. There is no keep screen on function on the phone during a call. You could just adjust the display timeout longer.
    What would suggest is to get Tasker. You can have it so that when in a call, your screen display timeour extends longer so it can keep the screen lit up during the call. Then it would automatically revert back to usual screen timeout after the call. Learning curve for the app is a bit steep though. But you can automate almost anything on the phone with it.
    05-30-2016 08:05 PM
  9. jamesmannes's Avatar
    Clean the proximity sensor area with a q-tip and rubbing alcohol.
    05-30-2016 08:24 PM
  10. joe_fresh's Avatar
    Is there a remedy??
    05-30-2016 09:45 PM
  11. ekendraed's Avatar
    The sensor is clearly visible. so I am not sure what the issue is.
    As soon as a call is established the screen goes blank whatever screen timeout setting. I now press the HOME button as soon as the screen goes blank if I wish to use the keypad or listen to the called party via the speaker phone.
    Which TASKER app do you suggest?
    05-31-2016 08:29 PM
  12. ekendraed's Avatar
    It is not necessary to do that as the sensor is clearly visible
    05-31-2016 08:31 PM
  13. ekendraed's Avatar
    As soon as I get a good padded flip cover I may remove the screen protector as the touch pad sensitivity is poor. Then hopefully the problem will get resolved
    05-31-2016 08:35 PM
  14. Kevin OQuinn's Avatar
    If you answered the phone while it was locked you're not "in the phone" you're just "in a call" which means you're under the rules of the lock screen.
    So if you press Home to light up the screen it will go dim again very quickly. If you fully unlock your phone (press Home to light it up, then Home again to go to lock screen) you should be under the rules of screen timeout/proximity sensor dimming.
    05-31-2016 08:51 PM
  15. ekendraed's Avatar
    Hi Kevin
    I am not in LOCK mode.
    Not sure what the problem could be
    05-31-2016 08:56 PM
  16. Kevin OQuinn's Avatar
    What is your screen timeout setting and how long to you sit on a call without powering on the display?
    05-31-2016 08:57 PM
  17. ekendraed's Avatar
    My screen timeout is set for 30 secs but this happens irrespective of what setting I use.
    When I make a call and as soon as the call action starts the screen goes blank. To see the screen I have to press the HOME button. I use a screen protector but the proximity sensor is clearly visible. This happens irrespective of the screen time out settings. Your help will be appreciated. Thanks
    05-31-2016 09:00 PM
  18. ekendraed's Avatar
    Message to all.
    PROBLEM SOLVED!!!
    I removed the screen protector and all OK. The screen does NOT go blank but will do if I cover the proximity sensor.
    Thank you ALL
    05-31-2016 09:09 PM
  19. gregjohnhall's Avatar
    OK guys am haveing exactly the same issue. I use a headset and have the phone on my desk during the day. I would like to see the display whilst I am on the phone. I don'tlike having to push the home button to hang up. Just a retarded feature.
    Thanks in advance.
    02-02-2017 08:59 PM
  20. gregjohnhall's Avatar
    Thanks in advance.
    02-02-2017 09:08 PM
  1. When phone is on mute Wil it still ring on a selected number
    Last Post: 06-06-2016, 04:57 AM
  2. Replies: 4
    Last Post: 05-30-2016, 07:51 PM
  3. Replies: 3
    Last Post: 05-30-2016, 10:53 AM
  4. My galaxy note 2 thinks that all calls are video calls
    Last Post: 05-30-2016, 07:52 AM
  5. Replies: 1
    Last Post: 05-30-2016, 07:14 AM
