Got a new s7 edge, notifications are enabled on the app and as well as in the phones settings for facebook but not receiving any notifications for new posts, etc. Any fix for this? Am I missing something somewhere?
Check the App optimization settings. If an app is set to save power, it will be prevented from using certain services in the background. So if for example Facebook messenger is on power save, it will not give you notifications.Got a new s7 edge, notifications are enabled on the app and as well as in the phones settings for facebook but not receiving any notifications for new posts, etc. Any fix for this? Am I missing something somewhere?
It's not just your phone, I am only getting random notices.Still trying to figure this out. Still wondering why android phones can't get facebook notifications. Seems like a simple feature.
I don't see that option under battery. The closest thing I found was by clicking "more" under battery, I could go to "optimize battery usage" and then disable facebook under "all apps". But that still isn't making facebook notifications come through on my phone.
And yeah, this is my first Android since the Motorola Backflip first launched in 2010. And I didn't have that long before switching to Windows Phone.
Facebook notifications didn't work on my S6. It just became something I accepted I needed to refresh the app and check for notifications because it was the only thing that annoyed me about the phone other than battery life. I haven't really noticed if it is something I am experiencing on the S7 because I have less than ten people that I'm friends with so I rarely get notifications
I suspect that the "system Facebook" and Play Store Facebook app do not behave the same. I disabled the system Facebook app and downloaded the Play Store version (did the same with Amazon).
While you can't uninstall a system app you can disable it.
Tab the MORE you'll see optimize battery usage
