At what percentage % do you charge your battery? (to help your battery lead a longer life)
- Not sure about official charging protocol/unwritten rules, but I usually slap my phone on a charger before bed; when it's usually between 15-45% (but usually, it'll be between 15-35%, because I Netflix before bed very often).
And yup! Most phones will stop charging when they reach 100% as a safety measure. Which is great, because when I let my phone charge overnight, it's not like I wake up when it immediately reaches 100%!
... Well, actually, that's sort of a lie. Sometimes that "fully charged" beep does wake me up.
Posted via the Android Central AppLaura Knotek and libra89 like this.06-01-2016 10:15 PMLike 2 - I don't even really see how charging at 80% versus charging at 40% makes a difference in the number of cycles. If I use 3600 mah of power a day. Whether I run my phone down to 0 before charging or charge around 60%, I'm still gonna use the same amount of power that day so overall the amount of cycles is the same.06-01-2016 10:33 PMLike 0
- If I understood correctly its about how much you stress the ions and their charge holding capacity. A good example would be, allowing it to discharge from 100 to 0 then back to full would give you 500 charge cycles. However, charging it at 50% always gives you 1500 cycles, instead of the 1000 cycles you would expect. So even if you charge twice a day, it would still allow the battery to last longer than draining it.06-01-2016 10:49 PMLike 0
- NexusGirlXRetired ModeratorI charge every phone I have at around 5-10% but usually when they hit that 5% warning when the display dims.06-02-2016 02:38 AMLike 0
Posted via the Android Central AppMorty2264 likes this.06-02-2016 08:25 AMLike 1 -
That would drive me crazy, but then again I have wireless chargers at work (2 for some reason) one as my car dock and 2 at home... one bedside and one in the living room so often it just sits there whether it needs it or not.libra89 likes this.06-02-2016 08:25 AMLike 1 - In this day and age of leased phones like T-Mobile's Jump On Demand program, Keeping a phone for a few months let alone 2 years makes battery longevity concerns none existent. If you're buying the device out right then you best have insurance, which will cover the battery as well. My point is, I use my devices as they were designed to be used, I don't cripple their functionality to eek out a few extra minutes of screentime, and I sure don't waste my time pondering what the perfect percentage point would be to recharge my phone. I have multiple wireless chargers throughout my home, office, and car. No matter whether the phone needs it or not, it will depending on usage end up on one of those chargers 1-4 times a day.
When the next Note is released, I get a new battery. If something should happen before then, I have insurance that will take care of it ...06-02-2016 08:28 AMLike 2 - AC published an article on Future Battery technology in Jan 2015. Well worth a read if you haven't done so.
Smartphone Futurology, Part 1
The author, Shen Ye, seems to be well versed in battery technology. In the article he makes these recommendations.
Tips for improving lithium battery longevity- Lithium batteries do not require conditioning, where you have to charge the battery for 24 hours on first charge.
- Leaving your phone on the charger after it’s charged won’t cause overcharging, except in very rare cases where the charging circuit malfunctions. Leaving a battery at 100% for long periods is not advised.
- Use fast charging sparingly where possible, higher temperatures quickens deterioration.
- Avoid charging at temperatures below freezing as subfreezing charging can cause irreversible electroplating of metallic lithium on the anode[16].
- Avoid discharging to 0%, it’s bad for the battery’s lifespan.
- Store lithium batteries at ~40-50% to reduce deterioration, also disconnect them from the device if possible.
Aquila and Laura Knotek like this.06-02-2016 02:59 PMLike 2 - AC published an article on Future Battery technology in Jan 2015. Well worth a read if you haven't done so.
Laura Knotek likes this.06-02-2016 05:48 PMLike 1 - thank you for all the replies. there's clearly people who care about their battery and people who want to just 'enjoy' using the phone as is. there are some people that are not part of a t-mobile program and don't have such services in their countries to get new phones every 1 year or 2 years. some of us want to use the phone for longevity. every phone that i use i want to make it last for around 4-5 years for me as i don't have money to waste for minor upgrades each year. the iphone 5 lasted me brilliantly for 4 years before i switched to s7libra89 likes this.06-03-2016 03:53 AMLike 1
- Thank you so much for your meaningful contribution to the thread!!!
http://4.bp.blogspot.com/_fTT9xlgZ9C...Smug+Alert.jpg
My contribution was simply addressing the folks who like to worry about things they really don't need to worry about.06-03-2016 09:42 AMLike 0 - If you're getting phone batteries to last 4-5 years then keep on doing what you're doing, you've figured this all out ...06-03-2016 09:45 AMLike 0
- The iphone 5 hasn't even been out 4 years....thank you for all the replies. there's clearly people who care about their battery and people who want to just 'enjoy' using the phone as is. there are some people that are not part of a t-mobile program and don't have such services in their countries to get new phones every 1 year or 2 years. some of us want to use the phone for longevity. every phone that i use i want to make it last for around 4-5 years for me as i don't have money to waste for minor upgrades each year. the iphone 5 lasted me brilliantly for 4 years before i switched to s706-03-2016 10:28 AMLike 0
- Lithium ion batteries don't care at what percentage you charge them at. They are not like the older NiCad batteries that would develop a charging memory.
These are different tech. Charge them however you want.
If my phone is sitting idle on my desk or on my coffee table, doesn't matter, I keep it on charger. That way it's ready with a full charge for however long I will be away from a charger when I go out!
Normal usage I get about 15 hours on my phone, it's not a Samsung tho.
Lg G406-04-2016 02:24 AMLike 0 -
- This is crazy how people think about this so much.. I literally just plus in my phone every night , so I can have a full charge the next day! I have an M8 and this thing is 2 years old. Still gives me 20 hours of battery life.. Granted I don't game or stream much but I'm also not a basic user either. So what's all the fuss about?TJA3500 and Bag of Leaves like this.06-04-2016 10:46 AMLike 2
Saying that, I've had a Nexus 4 since launch and that's obviously had quite a few charges since then and the battery still lasts as well as it did. I certainly haven't noticed any appreciable difference.06-04-2016 11:12 AMLike 0 -
- Then perhaps the best time to recharge your battery is above 60% or switch off fast charge as your default mode of charging and only use it when necessary?
Just turn on fast charging during times that you're in a hurry.ClintRo and Doc Marten like this.06-04-2016 07:28 PMLike 2 - This is pretty much what I do. Especially since I have a qi charger at work. I just set it down on there whenever I'm not using the phone. Leave work with a full charge, then put it on a wireless charger by my bed at night. I'll usually be at around 70% by the time I go to bed.06-06-2016 10:40 AMLike 0
- Forum
- Samsung Android Phones
- Samsung Galaxy S7 edge
Security question type life is good but it wont work why
By AC Question in forum Ask a QuestionReplies: 2Last Post: 09-09-2016, 11:33 AM -
Why does my samsung galaxy SIII mini shut down when it wants to?
By AC Question in forum Ask a QuestionReplies: 1Last Post: 05-31-2016, 03:06 AM -
Why can't I access to my google play store after Factory Reset?
By AC Question in forum Ask a QuestionReplies: 1Last Post: 05-31-2016, 03:01 AM -
Default dialer will not allow me to set a different one, because it's grayed out.
By neicyb1969 in forum Ask a QuestionReplies: 0Last Post: 05-31-2016, 01:52 AM -
my speech to text microphone is missing. how do i get it back
By AC Question in forum Ask a QuestionReplies: 0Last Post: 05-31-2016, 12:11 AM
