Yes because the battery heats up more on fast charging. Heat hastens battery deterioration.Would 200 fast charges be worse for the battery than 200 normal charges?
Well if you read my first post on the first page, you'll see that I said the best practice is to just top up the phone every time you can.Then perhaps the best time to recharge your battery is above 60% or switch off fast charge as your default mode of charging and only use it when necessary?
Saying that, I've had a Nexus 4 since launch and that's obviously had quite a few charges since then and the battery still lasts as well as it did. I certainly haven't noticed any appreciable difference.
Just turn on fast charging during times that you're in a hurry.
