06-02-2016 09:07 PM
26 12
tools
  1. love4speechless's Avatar
    A running app not necessarily would show up, especially if it's just using an Android OS service. GSAM for example just uses the Android OS battery watching service, hence any additional battery cost from GSAM would just add to Android OS under the battery usage charts. Same goes for other apps that work the same way.
    The GSAM you see on the battery chart may just pertain to the actual opening of the app.
    That makes sense cause my os and standby times always seem to be high but I know there's nothing really I can do to lower them and the phone is still operating as usual anyway xd
    06-02-2016 09:07 PM
26 12
  1. Darker 'translucent' Lines When I Change Brightness On My Galaxy S7 Edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 08-22-2018, 08:01 AM
  2. S7 Edge. Now on my 3rd due to the pink lines of screen death
    By lewchenko in forum Samsung Galaxy S7 edge
    Last Post: 08-16-2016, 04:58 PM
  3. S7 Edge horrible standby and battery, any fixes?
    Last Post: 06-02-2016, 08:55 AM
  4. Recover photos from broken s7
    By Dean Black in forum Samsung Galaxy S7
    Last Post: 05-31-2016, 09:30 PM
