joe01880
Then leave it on and quit whining or bragging, which ever your doing, enjoy!According to this it takes up 0.1% of battery xd
And I was kidding..get over yourself!!How was I "whining or bragging"? I was asking a question
A running app not necessarily would show up, especially if it's just using an Android OS service. GSAM for example just uses the Android OS battery watching service, hence any additional battery cost from GSAM would just add to Android OS under the battery usage charts. Same goes for other apps that work the same way.I already have screen on times of over eight hours but I was just curious. I never see gsam pop up in the apps using battery
The GSAM you see on the battery chart may just pertain to the actual opening of the app.
