I upgraded to the S7 edge last night (from the S4) and one thing noticeably different is that now I don't have a button to just turn off GPS anymore. I can turn off all of location (which turns off GPS) or I can leave location on and let the GPS drain my battery when I really don't need that precise of location.
Not having location on at all is problematic as many apps like to (or need to in the case of weather apps) have an idea of where you are. Now sure, I can change the mode to not use GPS, but then there are other apps (like driving apps or run tracking apps) that need the precision of GPS. Pretty crappy to have an elaborate jumping through modes routine every time I get into or out of the car.
So what gives? My understanding is that this changed back with the S5 or S6, so has anyone found a good middle ground? I hate when software takes away useful functionality. On the S4 I had to install a widget to enable/disable my data connection for when I wanted to save battery life and I wasn't online anyway, something that was originally one of the shortcuts.
Thanks all
