1. mirella green's Avatar
    Help! I have only had this phone for a couple of hours and I am already about to destroy it in frustration. It simply won't recognise my fingerprint, it did at first then it upgraded some stuff now I can't get into it again. I currently have to wait an hour before I can try again, I have set a 4 digit password but it's not giving me the option to enter it. I suppose it doesn't help that this is my first samsung/android phone for many years so I'm not that familiar with it. Lets hope it makes it through the night, at this rate it may not!
    Thanks
    06-04-2016 04:58 PM
  2. MarqBland's Avatar
    When you set up your fingerprint, you didn't "swipe" your finger across the reader, correct? That's a common reason for fingerprint failure.
    06-04-2016 05:47 PM
  3. mlblack16's Avatar
    Once enough failed attempts have occurred then it won't even let you enter a pass code.
    If you only did one set of fingerprint scans to record, it doesn't work well. If you enter all scans with both thumbs you have a better chance at it being recognized.
    It is very touchy and the slightest change can cause issues (fingers being wet or even recently washed, any food debris, etc on your fingers, too much smudge on the home button).
    I just installed the latest good lock app from the Samsung app store and I swear it is registering fingerprints much better with this lockscreen.
    06-04-2016 07:02 PM
  4. chanchan05's Avatar
    When you entered the fingerprint, you should have tried registering a little angled to the side, a little above and all that scenarios where the finger isn't perfectly aligned with the scanner.
    06-04-2016 07:32 PM
  5. mirella green's Avatar
    Thanks and if I ever manage to get into the phone I'll bear all your advice in mind. In the meantime can anyone tell me how to get into my phone?????
    06-05-2016 04:07 AM
  6. chanchan05's Avatar
    When it allows you to enter the fingerprint, instead entering it, swipe the screen to reveal the pin code entry. Alternatively you can reset the passcode through Find My Mobile or Android Device Manager.
    mirella green likes this.
    06-05-2016 04:38 AM
  7. mirella green's Avatar
    Thankyouthankyouthankyou As I said I have not had a samsung phone for many years, so am at ***** level when dealing with it. Now deleted fingerprint and it might be a while before I have the confidence re-enter it.
    Thanks again, you have saved the life of a phone today.
    06-05-2016 05:51 AM
  8. mirella green's Avatar
    Wow, you can't say ***** (idi0t ) on here? Thats harsh
    06-05-2016 05:53 AM
  9. chanchan05's Avatar
    You can enter 4 fingerprints anyway, for four different fingers. Just in case. And it will always allow you to just swipe the screen.
    06-05-2016 06:42 AM
  10. PJRed2008's Avatar
    The nannyship level here is very high.
    06-05-2016 09:35 AM
  1. Anyone else unhappy with the audio quality of the Galaxy S7 Edge?
    By gwdetroit in forum Samsung Galaxy S7 edge
    Last Post: 09-07-2017, 11:14 PM
  2. Marshmallow for T-Mobile note edge?
    By HatchNRA in forum Samsung Galaxy Note Edge
    Last Post: 06-05-2016, 01:01 PM
  3. Replies: 1
    Last Post: 06-04-2016, 04:18 PM
  4. Marshmallow for T-Mobile note edge?
    By HatchNRA in forum Samsung Galaxy Note 4
    Last Post: 06-04-2016, 03:23 PM
  5. Contact image not showing when receiving incoming phone calls.
    By pascaldemo in forum Samsung Galaxy Note 4
    Last Post: 06-04-2016, 01:21 PM
