1. kasparov909's Avatar
    Hi guys
    Wanted some advice, my S7 edge will every few days start typing on its own in whatts app and will flicker between screens, apps will move on their on and Its as if I dont have control over the phone.
    What could the problem be?
    Max
    06-05-2016 08:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this only happen when plugged in and charging, or does it happen any time?
    06-05-2016 09:26 PM
  3. chanchan05's Avatar
    A similar issue has been posted before of various forums. Seems that poor quality screen protectors are causing ghost touches on the Edge, to the point that some phones become unusable. Do you have a screen protector?
    B. Diddy and Icarrabba like this.
    06-06-2016 01:30 AM
  4. coolkenny13's Avatar
    Restart your device and let us know if this help
    Second option do a factory reset.
    Have you installed any apps latetly.
    06-06-2016 01:34 AM
  5. love4speechless's Avatar
    My phone did similar to this and I had to get a replacement device
    06-06-2016 01:36 AM
  6. Icarrabba's Avatar
    My phone was doing the same thing. Thanks chanchan05. I removed the screen protector and my problem was resolved.
    09-26-2016 06:51 PM
  7. sanchez498's Avatar
    My S7 edge just started doing this also. Acts like it has a mind of its own.goes between screens on its own opens up stuff at random. Push's buttons on its own. And no i have no recent apps i installed. Spent most of 3 hrs on the ph with verizon tech. Did 2 hard resets and it still does it. Solution they are sending me a new ph. But i did have 2 major updates 2 weeks in a row and i am thinking the second update is what did this. Not real sure though.
    09-28-2016 07:51 AM
  1. Samsung S7 Screen Off App
    By exchef in forum Android Apps
    Last Post: 06-08-2016, 02:01 PM
  2. Travel landscape wallpaper of S4 or 5
    Last Post: 06-06-2016, 04:22 AM
  3. Taking Your Phone Overseas (Verizon Samsung S7 Edge)
    Last Post: 06-06-2016, 04:21 AM
  4. Why geeks in cubicles should not decide the fate of functionality
    By InReality01 in forum Legacy Android & Other OS's
    Last Post: 06-05-2016, 09:48 PM
  5. how can i fix 'Unfortunately,TouchWhiz home has stopped'?
    Last Post: 06-05-2016, 08:13 PM
