1. Profcool's Avatar
    Hi there, does anyone know of a way to mute calls using the physical buttons on the supplied Samsung headset. I'm used to being able to do this on my work Blackberry but on the Edge 7 the middle button just kills the call. I dial into lots of work conference calls a physically muting yourself is much easier than trying to do it on the phone.
    Also as an aside, does anyone know if it is possible to mute/unmute using a Gear S2?
    Thanks
    06-06-2016 04:22 AM
  2. Cheesewiz32's Avatar
    For a phone call:
    When a call comes in you can send to voicemail by pressing-and-holding the select button (The small roundish button on the headset).
    While on a call you can mute yourself by pressing-and-holding the select button (The small roundish button on the headset).
    Edit: Yes I think this is backwards, a short press should mute and a long press should hang up the call...
    08-29-2016 01:41 PM
  1. Muting calls using headset
    Last Post: 06-06-2016, 04:01 AM
  2. android device managers call is mute.
    Last Post: 06-06-2016, 03:57 AM
  3. Replies: 1
    Last Post: 06-06-2016, 02:24 AM
  4. Replies: 1
    Last Post: 06-05-2016, 10:11 PM
  5. Can I Use My Moto Turbo Charger?
    By RicKaysen in forum Samsung Galaxy S7
    Last Post: 06-05-2016, 05:01 PM
