1. AC Question's Avatar
    The S-voice had been working great. Now it appears to be listening but the blue circle just spins and spins and then stops and there is no response to my command. I have restarted the phone without result. I saw in a previous post for the S6 to try clearing the S voice cache in applications manager but I do not see that on my phone following those directions.
    06-06-2016 09:14 AM
  2. Alanhd's Avatar
    Ive had nothing but problems with S voice, normally a reboot fixes the issues but I ditched it for Google Voice.
    S Voice app shows for me in application manager
    06-06-2016 02:59 PM
  3. Elcha33's Avatar
    Havong same issue. I am contacting the cellphone provider, updating if there is solution.
    06-06-2016 04:04 PM
  4. Patrick Jean's Avatar
    I do have the exact same behavior with my S7 today !
    I tried to reset s voice by desabling it and reanabling it but it didnt change anything.
    I hope it will be fix soon.
    06-06-2016 06:51 PM
  5. Patrick Jean's Avatar
    Well, it looks like it was just à minor bug. Everything is working fine today.
    I hope it s the same for you?
    06-07-2016 09:08 AM
  1. Replies: 3
    Last Post: 03-03-2017, 08:24 PM
  2. Samsung S6 Edge 'lte' or '4G' symbol?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 06-07-2016, 08:42 PM
  3. Replies: 1
    Last Post: 06-06-2016, 10:51 PM
  4. Can't reset time to eastern standard time on my tablet, how can I do it?
    Last Post: 06-06-2016, 10:50 PM
  5. Replies: 0
    Last Post: 06-06-2016, 09:12 AM
