06-09-2016 07:56 AM
30 12
tools
  1. D13H4RD2L1V3's Avatar
    Come to think of it, don't a lot of phones get warm under sustained use?
    On my former daily LG G4, for example, the processor once went above 158 degrees during sustained use. The battery was just shy of 105 degrees, but it was still hot enough to make the top portion of the screen pretty darn toasty, to the point where touching it for more than a second was almost uncomfortable.
    And yes, the heat was one of the reasons why I'm no longer using it as my daily. I know phones get warm under sustained use, but if it gets pretty hot while it's in my pocket, then we have a problem.
    06-07-2016 11:30 PM
  2. Guatiao's Avatar
    What Android version does your G4 have?
    06-08-2016 08:09 PM
  3. digitalbreak's Avatar
    Mine gets hot, around 40°C if I use:
    1) Google Photos app to stream content to Chromecast.
    2) Using the phone when Google Play updates my apps (not when I select an app to install, but when I go click 'Update All')
    I just can't understand how Google can let this slip or otherwise it could very well be Samsung's issue.
    And, when I used Samsung Good Lock lock screen, my phone was always warm.
    Anybody else seeing similar issues?
    06-08-2016 09:02 PM
  4. D13H4RD2L1V3's Avatar
    Marshmallow 6.0, but it also got that warm on 5.1 Lollipop.
    R.I.P GPe program
    06-08-2016 11:04 PM
  5. Dan TheMan86's Avatar
    Mine gets hot every time when updating all. I've also don't understand why it can only download and install the apps one at a time. On windows phone it would download one, start installing, then download the next app and so on. You didnt have to wait for an app to completely install before it started downloading the next one
    06-09-2016 07:56 AM
30 12
  1. For Gear VR: Galaxy S6 vs S7?
    By badogblue in forum VR Headsets
    Last Post: 06-28-2016, 02:56 AM
  2. Should I trade a 6p for galaxy s7
    By 66SMASHerG25 in forum Samsung Galaxy S7
    Last Post: 06-10-2016, 12:06 AM
  3. trade 6p for s7?
    By 66SMASHerG25 in forum Nexus 6P
    Last Post: 06-06-2016, 05:04 PM
  4. Replies: 1
    Last Post: 06-06-2016, 03:15 PM
