1. Kasper610's Avatar
    Has anybody figured out how to change the twitter notification sound without it going back to default? This is so annoying!
    06-08-2016 06:31 AM
  2. H3aTeRzz's Avatar
    Don't use twitter, nor do I have the s7. Here's a suggestion though. Uninstall Twitter, enter recover and wipe cache partition, then reboot, reinstall and see if that helps.
    06-08-2016 11:15 AM
  1. Cracked glass at the back - to fix or not to fix?
    By LordFarkward in forum Samsung Galaxy S7 edge
    Last Post: 08-30-2016, 06:35 AM
  2. The G5 and Seawater don't mix well :-(
    By tabberkev in forum LG G5
    Last Post: 06-15-2016, 01:21 AM
  3. Replies: 2
    Last Post: 06-09-2016, 08:31 PM
  4. should i flash "BL - CP - CSC" or only the AP file in odin?
    Last Post: 06-08-2016, 07:00 AM
