04-01-2017 10:03 PM
35 12
tools
  1. Geoff Stuart's Avatar
    Just to be clear -- your issue is that your fingerprint sensor never seems to recognize you, is that correct? This is a somewhat older thread, so I just want to make sure your issue isn't different from the original post.
    It recognizes me very rarely, like 5% of the time. I have tried registering the same thumbprint as Fingerprint 2 and 3, figuring that maybe if I gave it more samples it would work right. Funny though, I also have Lastpass on the phone and it never has a problem recognizing my thumbprint. But Lastpass is not involved with unlocking the phone, so I don't believe it's involved with my phone unlocking, only unlocking Lastpass once I'm already using the phone. It worked better prior to the 6.0.1 update.
    03-22-2017 08:21 PM
  2. S3NTYN3L's Avatar
    Go into Settings > Lock screen and security > Secure Lock Settings,
    Turn on "Lock instantly with power key".
    See if that corrects the issue for you, it did for me.
    (I must have "fat-fingered" the setting in question while changing the "Lock automatically" timeout setting above it).
    03-24-2017 02:01 PM
  3. Geoff Stuart's Avatar
    <<Turn on "Lock instantly with power key".>>
    That setting is not on the Secure Lock Settings screen on my Galaxy S7.
    03-30-2017 08:49 AM
  4. LineKill's Avatar
    Since the settings vary by carrier, while in the settings tap the search icon at the top and type "lock instantly".
    03-30-2017 09:43 AM
  5. Geoff Stuart's Avatar
    "No results found"
    I just got the Nougat 7.0 update and am installing it now. Will update this thread after i test it out.
    03-30-2017 11:03 AM
  6. B. Diddy's Avatar
    It might also be called "Automatically Lock."
    03-30-2017 05:08 PM
  7. LineKill's Avatar
    On the Verizon variant there is also Lock Automatically. It is a separate setting from Lock Instantly. But you know how carriers like to mess with things😉
    B. Diddy likes this.
    03-31-2017 12:19 AM
  8. Geoff Stuart's Avatar
    Well, the upgrade to 7.0 dids nothing to help this problem. I deleted and re-added fingerprints and it still does not recognize me.
    04-01-2017 09:06 AM
  9. B. Diddy's Avatar
    Is the phone still under warranty? Maybe the sensor is failing.
    04-01-2017 05:14 PM
  10. Geoff Stuart's Avatar
    Far too much trouble to go to. I'll try other security features.
    04-01-2017 10:03 PM
35 12
  1. I keep getting the audible message: when it's safe you'll first need to...
    Last Post: 12-13-2018, 11:50 AM
  2. Replies: 1
    Last Post: 06-16-2016, 04:48 AM
  3. Login to facebook with my profile picture
    Last Post: 06-15-2016, 05:36 AM
  4. doanloading pictures from galaxy s5 to windows 10 pc
    By AC Question in forum Samsung Galaxy S5
    Last Post: 06-09-2016, 06:39 PM
  5. Why I cannot see my Accessibility Services For Applications?
    By Reshma R in forum Android 4.4 KitKat
    Last Post: 06-09-2016, 03:47 PM
