06-17-2016 10:33 AM
36 12
tools
  1. dpham00's Avatar
    Just noticed dphan00's screenie in post #9 showing that the Verizon release is based on PE1 which is 8 firmware builds before the PE9 build that those bugfixes and enhancements were released on and 25 firmware builds before the 26 May build that PEQ is being currently released on for the Global models of S7 & S7 Edge. It looks as though the usual lag between Verizon's own firmware releases and the stock Samsung releases has begun already.
    It "began" when the phone was released.
    With that said, Samsung /verizon has improved a lot with regards to updates.
    ironass likes this.
    06-11-2016 09:24 AM
  2. ironass's Avatar
    I think that on the U.S. carrier branded phones, the increase in the frequency of updates is more to do with the Federal Communications Commission (FCC) and Federal Trade Commission (FTC) than it has with the U.S. carriers.
    Think Android security updates take too long to roll out? So do the FTC and FCC
    So, while you may not see actual bugfix and firmware updates as frequently as the Global model, the U.S. models should at least be up-to-date with security patches.
    06-11-2016 09:41 AM
  3. dpham00's Avatar
    I would say that depends... The Verizon 10 received a software update on May 26th, yet still remains on the March update.
    http://forums.androidcentral.com/sho....php?p=5207359
    The g5 received an update on May 11th and is currently on the April security patch.
    http://forums.androidcentral.com/sho....php?p=5171540
    So even before this update, the Verizon s7 was on the May security patch, and with this update, it is now on the June patch. I think that Samsung is as of late above the pack in terms of security updates.
    Hopefully the trend will continue
    ironass and clintw22 like this.
    06-11-2016 11:57 AM
  4. Shamalk's Avatar
    Does anyone know what the two dots are for in the update screen top left corner. see the picture.June Firmware Update - Verizon S7-s7-update-2-dots.png
    06-11-2016 06:03 PM
  5. PetitHerisson14's Avatar
    Does anyone know what the two dots are for in the update screen top left corner. see the picture.Click image for larger version.
Name:	S7 Update 2 Dots.png
    The first dot is for the system update and the second dot is for apps optimisation
    06-11-2016 06:38 PM
  6. dorlisa's Avatar
    I just installed the update, does anyone know which issues it is suppose to correct? I am praying the WIFI issue I received after the last update.
    06-12-2016 09:59 AM
  7. jonty12's Avatar
    My Samsung pay won't work now.
    Used it a bunch today... working now. Got two "that's so cool" and one "we don't have sensors... holy shi.."
    06-12-2016 08:49 PM
  8. anon(19981)'s Avatar
    There is a glitch in my phone since the June security update. Every time I get out of range of Wi-Fi and I'm playing anything via Bluetooth it will quit playing over headset or car (Sync) and play over phone speaker. Once I switch the audio back to whatever Bluetooth device I am using it will work fine until next time I leave a connected Wi-Fi area.
    06-13-2016 08:08 PM
  9. Fryhod's Avatar
    My s7 wont wireless charge after the new update. Anyone else have this problem?
    06-16-2016 03:44 PM
  10. Jaycemiskel's Avatar
    Nope. Wireless charging still works great for me.
    06-16-2016 04:52 PM
  11. clintw22's Avatar
    Works for me also. Maybe it's ur pad?
    06-17-2016 10:33 AM
36 12
  1. OTA update problem
    By dannywalls76 in forum Sony Smartwatch 3
    Last Post: 06-11-2016, 12:21 AM
  2. Hypothetical Situation: Android OS Updates vs. Security Updates
    By Ry in forum General News & Discussion
    Last Post: 06-10-2016, 09:50 PM
  3. Why is my Samsung S7 Edge screen dull & faded?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 06-10-2016, 11:31 AM
  4. LG G3 Lollipop 5.0.1 update app issues
    By HeavenLe831 in forum LG G3
    Last Post: 06-10-2016, 10:30 AM
  5. Buuble in Galaxys S7 edge display
    Last Post: 06-10-2016, 09:05 AM
