Is the Galaxy S7 edge compatible with Android Auto?
Printable View
Yes it is. HOWEVER, some users report mixed results depending on the unit they're trying it in. Most of the time an update to the car system (if available) solves connectivity issues.
Works in my optima.
The answer is yes, with the right USB cable.
See this thread: http://forums.androidcentral.com/and...roid-auto.html
