1. VeeHarsh's Avatar
    The contents of "Developer Options" in my Samsung Galaxy S7 Edge have vanished.
    It now says "Developer options are not available for user". Along with it, I can now no longer see the notifications, or even
    drag down the menus from home screen to see all the options and even the apps running in background.
    Anyone has any idea as to what the problem could be and possible solution?
    06-13-2016 04:48 AM
  2. VeeHarsh's Avatar
    I have tried tapping on the build number. But, it was of no use
    06-13-2016 06:44 AM
  3. abcomputin's Avatar
    Have you tried shutting it off for a few minutes, then powering up?
    06-13-2016 05:32 PM
  4. VeeHarsh's Avatar
    Tried. It seems to have no effect.
    06-14-2016 02:26 AM
  5. VeeHarsh's Avatar
    After going through all the available settings, had no option but to do a factory reset.
    The functionalities are working as expected now. But, still not sure what caused that.
    06-14-2016 04:10 AM
  1. [POLL] Whom do you like to play 44 Chairs with the most?
    By GOLD APPS in forum Android Games
    Last Post: 07-14-2016, 03:23 AM
  2. Old battery messes up the clock - huh?
    By tabberkev in forum LG G5
    Last Post: 06-29-2016, 06:34 PM
  3. Replies: 1
    Last Post: 06-13-2016, 04:29 AM
  4. Why screen mirring option not available on Lolipop
    Last Post: 06-13-2016, 04:24 AM
