1. Alanhd's Avatar
    Hi, here's a question for anyone who uses slow motion video on the S7/S7e.
    How is it at tracking fast moving objects.
    Tommorrow the Flying Scotsman train is due to make a visit through were I am. I was going to set my video camera and my phone up on tripods to record video and shoot handheld with my DSLR. I won't bother with the phone if it's not likely to track fast enough.
    Has anyone tried it in a similar situation.
    06-14-2016 08:08 AM
  2. flintlock's Avatar
    If you use a slow motion setting all you'll accomplish is a video of a train that looks slower.
    If you want your images to show speed the basic technique is to pan the train. Use a lower ISO setting and an aperture that keeps the shutter fairly slow. It helps to use a tripod that lets you pan to keep the train perfectly clear.
    Another way is to keep the camera steady and let the train blur. This gives the impression of speed but you won't see the train well.
    06-14-2016 10:10 AM
  3. Alanhd's Avatar
    I plan on editing the slow motion video into the normal footage taken. Hopefully get some nice steam discharge as it comes around the bend. Both video cameras will be locked down as I will be shooting stills handheld. Shooting the stills has never been a problem with other steam trains but I've never used the S7 to video in that situation.
    The train will be coming towards me so I'm not dure how the S7 will behave. Might go out tonight and try it with some normal trains and see how it is.
    06-14-2016 01:25 PM
  4. ironass's Avatar
    Hope you have better luck than this guy...
    pjwk81 likes this.
    06-14-2016 05:29 PM
  5. Andyvalver's Avatar
    It should handle it fine. I find the video great ton my s7 edge. You could put it in 1080p 60fps mode. That will give you good video and you can slow it down to half speed just fine.
    Posted via S7 edge 😍
    06-14-2016 05:45 PM
  6. Alanhd's Avatar
    I would be super gutted. Just praying the rain holds of tomorrow. This will be the last chance to see it in ages. I grew up where it was built, used to be the highlight of the week going to see the engines that were in the works.
    06-14-2016 05:46 PM
  1. How to make video calls from MOTO G4 Plus
    Last Post: 10-26-2016, 02:39 PM
  2. Replies: 1
    Last Post: 06-16-2016, 08:37 AM
  3. How to record videos @ 60 FPS?
    By Snappy Phoenix in forum HTC 10
    Last Post: 06-15-2016, 12:17 PM
  4. I can't send a home video via email on my Note4
    Last Post: 06-14-2016, 10:26 AM
  5. Question on usage of Android Pay
    Last Post: 06-14-2016, 12:13 AM
