1. justforfunz's Avatar
    Hi there, just to check anyone using spigen s wallet case? So far how is it going?
    I'm concern with the 3 strong magnets that helps to hold the strap.. so.. if anyone does have it, so far how's your phone performing?
    What about using gps such as google maps within the case? Is it performable?
    I had this case for months on my shelf but am hesitating to use as I was told magnets could damage your phone hardware components.. is it true? Such as magnetometer
    06-15-2016 08:29 AM
  2. danlnyc's Avatar
    It's like $20 bucks bro. Go to amazon, purchase, and if you don't like it return it.
    Magnets will not affect any of your phone functions.
    06-15-2016 07:24 PM
  3. justforfunz's Avatar
    I already got it.. can't return since I have it for months already... and are you sure... I tested by putting my phone near this case, it affects the reading. I don't mind though, just worried it will cost permanent damage to phone hardware
    06-16-2016 01:00 AM
  4. Mr_Spencer's Avatar
    I remember this being an issue with the nexus 2012 tablets. The magnets in folding cases were killing them. I wouldn't be surprised if a strong enough magnet messed with the things ur mentioning.
    06-16-2016 02:02 AM
  5. Trent9810's Avatar
    Spigen walet case is my favorite. Great case with no issues.
    08-07-2017 10:48 AM
  1. samsung s7 edge = Apps edge
    Last Post: 06-20-2016, 10:57 AM
  2. S7 edge spigen s wallet case
    Last Post: 06-15-2016, 08:17 AM
  3. Temperature too low to charge S6 edge
    Last Post: 06-15-2016, 05:53 AM
  4. Review Tudia case Slim-fit MERGE Dual Layer
    By Bruno Slivar in forum LG G5
    Last Post: 06-15-2016, 05:48 AM
