1. King Mustard's Avatar
    I have a Samsung Galaxy S7 Edge and, when I'm home (and on my home Wi-Fi), I'd like to not need to unlock my phone each time.
    Is this possible?
    06-15-2016 01:07 PM
  2. Laura Knotek's Avatar
    Yes, that is possible.
    Please take a look at this article for instructions.
    It will use your GPS, not your WiFi.
    06-15-2016 01:09 PM
  3. King Mustard's Avatar
    I do not have that option.
    06-15-2016 01:21 PM
  4. Almeuit's Avatar
    Hmm odd -- what version of the phone do you have (carrier, unlocked, etc.) ?
    06-15-2016 01:45 PM
  5. King Mustard's Avatar
    Unlocked SM-G935F running Android 6.0.1.
    06-15-2016 01:48 PM
  6. stang6790's Avatar
    What lock method are you using? I believe you have to be using something other than swipe for the option to show.
    06-15-2016 04:10 PM
  7. King Mustard's Avatar
    Fingerprints, with PIN as a backup.
    06-15-2016 04:14 PM
  8. chanchan05's Avatar
    That's weird. I have fingerprint+PIN as well. What happens if you use the settings search?
    06-15-2016 07:04 PM
  1. Replies: 1
    Last Post: 06-15-2016, 07:48 PM
  2. Can i bypass the set up wizard on my HTC 1 4g lyt
    By Shell-rae72 in forum Ask a Question
    Last Post: 06-15-2016, 04:06 PM
  3. where can I find my phone number listed in my Galaxy S7 Edge
    Last Post: 06-15-2016, 01:02 PM
  4. Replies: 0
    Last Post: 06-15-2016, 12:20 PM
  5. Transfering contacts from iPhone 5s to LG Stylo2
    Last Post: 06-15-2016, 12:17 PM
