1. sLithery's Avatar
    Hello,
    since some days my USB port is not working correctly.
    It takes up to 6 hours to charge my phone(changed the cable multiple times).
    If I plug in my Gear VR into my phone the phone recognizes my Gear VR for like five seconds and automatically unplugs it.
    I already tried to clean my USB port and did a factory reset.
    ty
    06-16-2016 08:04 AM
  2. H3aTeRzz's Avatar
    Hi
    I do believe you've done all that we would suggest. If your device did not receive damage by your actions, for example, a fall or liquid damage, they your drive will be covered under warranty. I would suggest contacting samsung support. If you damaged the phone know they won't cover it, then I would suggest bringing it to a local service center, as they'll probably be cheaper for repair.
    Chris
    06-16-2016 08:11 AM
  3. sLithery's Avatar
    I have a scratch on the frontside besides the home button(screen is still working). That happened like a month ago or so and the USB port was still working. It stopped working like a week ago.
    06-16-2016 08:16 AM
  4. H3aTeRzz's Avatar
    I have an s6 active, that I dropped, and the screen died, it only had 2 small bumps on the bezel. I sent to samsung, and they replaced at no cost to me. I would suggest sending it in. They won't charge you unless they contact you first....if they see that a charge is necessary, they'll contact you first. If you don't want to pay, they mail it back at no cost to you.
    Chris
    06-16-2016 05:58 PM
  1. Replies: 7
    Last Post: 06-28-2016, 03:04 AM
  2. New AT&T Update - Not MM, security patch
    By natehoy in forum Samsung Galaxy Note 4
    Last Post: 06-16-2016, 08:28 PM
  3. My intex aqua HD phone is dead and not show the charging
    Last Post: 06-16-2016, 05:40 PM
  4. Replies: 1
    Last Post: 06-16-2016, 03:55 AM
  5. Replies: 0
    Last Post: 06-16-2016, 01:49 AM
