1. Approvoi's Avatar
    Since 2 nights ago, my overnight batt drain is greater than 50% more than the day drain. I installed batman apk and suspect that could be the cause.
    Any experts out there to comment or had a fix
    06-16-2016 06:53 PM
  2. Morty2264's Avatar
    So, your battery drops by 50% overnight? Can you delete that install and then see what happens?
    Please post a screenshot of your daily battery usage (found in your Settings app), so we can take a closer look. Thanks, and good luck!
    06-16-2016 08:26 PM
  3. Almeuit's Avatar
    Can you post some screenshots?
    06-16-2016 08:47 PM
  4. Approvoi's Avatar
    Attached
    06-16-2016 08:53 PM
  5. Approvoi's Avatar
    Here are the screens
    06-16-2016 08:56 PM
  6. chanchan05's Avatar
    Batman apk? A pirated batman game app? Probably the reason. Sometimes those stuff contain malware (viruses) that steal data or push ads.
    06-16-2016 09:19 PM
  7. Approvoi's Avatar
    That's the apk with the batman theme limited edition
    06-16-2016 09:42 PM
  8. mar29020's Avatar
    battey life is pathetic. i charged fully at 4pm and its already at 56% just by lightly browsing the internet.
    06-16-2016 10:04 PM
  9. mar29020's Avatar
    Since I'd know you will ask...
    06-16-2016 10:06 PM
  10. love4speechless's Avatar
    How exactly is this supposed to be bad battery life?
    06-17-2016 07:23 PM
  11. Approvoi's Avatar
    Same case again. Drop 30 % while I sleep. If you look at the chart it is steeper at night compared to day time.. Any comments?
    06-17-2016 07:34 PM
  12. Laura Knotek's Avatar
    Does the Batman theme have a live wallpaper?
    06-17-2016 07:40 PM
  13. Approvoi's Avatar
    I am removing the theme to see if it improves. Yes. It has live wall paper
    06-17-2016 09:11 PM
  14. Laura Knotek's Avatar
    Please let us know if that helps.
    Live wallpaper tends to be a cause of battery drain in many cases.
    06-17-2016 09:19 PM
  15. Approvoi's Avatar
    But screens are off during night..
    06-17-2016 09:30 PM
  16. Iva_LadyDiCaprio98's Avatar
    It could be that the live wallpaper is preventing the phone from dozing, even with the screen off
    06-17-2016 10:09 PM
  17. Approvoi's Avatar
    If that's true it's good knowledge for everyone
    06-17-2016 10:14 PM
  18. Approvoi's Avatar
    Resolved after using a normal theme - sevenabstract. Overnight drain less than 10%. Compare the gradient of drain after 12am and above screen shots.
    06-18-2016 08:53 PM
  1. Samsung s6 Battery Drain
    By Hades God Slayer in forum Samsung Galaxy S6
    Last Post: 06-19-2016, 10:04 PM
  2. Higher battery use on Marshmallow
    By pduffer in forum Samsung Galaxy Note 4
    Last Post: 06-17-2016, 09:28 PM
  3. 3.8 battery for galaxy note 4 will it still work?
    Last Post: 06-16-2016, 05:02 PM
  4. Why is Android OS using an insane amount of battery.
    Last Post: 06-16-2016, 03:00 PM
  5. battery doctor lock screen nexus10
    Last Post: 06-16-2016, 02:00 PM
