1. Killer BIGxyz's Avatar
    Ive had this issue for about 2 weeks now, and my battery is dead by 5pm when i fist got the phone at launch it would last until about 8-9
    Ive followed some guides such as resetting my cache and disabling google services but its still bad atm
    Currently at 33% cell stanby
    06-16-2016 10:14 PM
  2. koves's Avatar
    I have this issue with my note 5 ... haven't found a fix for it yet
    Hopefully samsung sends out a patch to fix this
    06-16-2016 10:20 PM
  3. chanchan05's Avatar
    Turn off Google Back Up
    06-16-2016 11:21 PM
  4. Bogy's Avatar
    Not sure which Google Back Up you meant. There's the Photo back up, and then the back up for passwords, wi-fi, apps, etc. Really didn't want to lose the back up on all that, but I already have my photos linked to my OneDrive account, so the Google Photo Backup was redundant, so I turned that off last night. I had noticed a significant change in the past few days on my battery life. I'm not sure just what changed, but I was also seeing a big increase in Cell Standby. After turning off the Photo Backup last night Cell Standby is now way down the list at 9% usage, and at 11:30 am I am still at 90% battery. I haven't used my phone a lot this morning, but that is significantly better than I had been doing the past few days, and back to what I was getting before the last Verizon update.
    06-17-2016 11:23 AM
  5. vientiane's Avatar
    I have learned that the google play music was the cause ( in my situation, everyone else maybe different), once I disable it, the problem is gone.
    06-17-2016 12:30 PM
  6. Killer BIGxyz's Avatar
    Can you give me a step by step to disable this? Sry im new to android
    06-17-2016 03:55 PM
  7. chanchan05's Avatar
    The data backup was recently linked to having issues with Doze not working properly. But yeah, redundant processes needs to be turned off for less battery use.
    06-17-2016 04:43 PM
  1. Samsung s6 Battery Drain
    By Hades God Slayer in forum Samsung Galaxy S6
    Last Post: 06-19-2016, 10:04 PM
  2. System ui battery overnight drain 50%
    By Approvoi in forum Samsung Galaxy S7 edge
    Last Post: 06-18-2016, 08:53 PM
  3. 3.8 battery for galaxy note 4 will it still work?
    Last Post: 06-16-2016, 05:02 PM
  4. Samsung s6 Battery Drain
    By Hades God Slayer in forum Android 6.0 Marshmallow
    Last Post: 06-16-2016, 03:46 PM
  5. Why is Android OS using an insane amount of battery.
    Last Post: 06-16-2016, 03:00 PM
