1. djin25's Avatar
    I made the mistake of trying to download an APK game file, which just gave me no results. I deleted the APK files, and etc. But now, every time I turn my screen and unlock it, it goes straight into an ad for like a app, or a survey. I looked into my application manager, and found something weird. I looked through all the apps, and found an app with no name, and the picture was just a white background. You khow how the Snapchat logo is just the yellow background, and white ghost. This app is just a white background. When I click to see for info, all I get is it is Version 1.0, and I can't uninstall it or pause it. I have a good feeling this is the cause for all my ads. Can someone help me with my situation. It's much appreciated.
    Attached Thumbnails Unkwown Ad Application on S7 Edge-screen-shot-2016-06-18-6.39.56-pm.png
    06-18-2016 05:43 PM
  2. chanchan05's Avatar
    Are you sure there's no other cause? Apps by Cheetah Mobile like Du, Clean Master etc? ES explorer also puts ads on opening the lockscreen.
    Well, you might have to factory reset. Failing that you'll have to root your phone to get rid of an ad app that embedded itself as system app since factory reset can't delete that.
    Thiscrapsucks35 likes this.
    06-18-2016 06:32 PM
  3. Bag of Leaves's Avatar
    Have you tried one of the apps made to seek out which apps are causing ads?
    06-21-2016 04:18 AM
  4. Stwutter's Avatar
    If you go into your file manager, try and do a search for files for whatever the game/APK was called. It may bring up a file(s) that you can delete. Obvs be careful that they are obviously to do with that rather than deleting critical stuff...
    06-21-2016 06:06 AM
  1. Replies: 2
    Last Post: 06-19-2016, 08:37 AM
  2. Replies: 1
    Last Post: 06-19-2016, 08:28 AM
  3. My phone uninstalled a bunch of stuff on its own
    By Nomekop777 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-18-2016, 06:56 PM
  4. Replies: 1
    Last Post: 06-18-2016, 04:28 PM
  5. How do I get past the Parking break is not on screen?
    Last Post: 06-18-2016, 03:07 PM
